Author Topic: PO 442 code 2002 GMC Envoy, can't figure it out?  (Read 14545 times)
Offline LTZ C20
Re: PO 442 code 2002 GMC Envoy, can't figure it out?
« Reply #15 on: May 28, 2015, 04:59:49 pm »
No you don't, my uncle did this on accident, the explosion gave my mom a rash for 2 weeks on her face and arms.
LTZ Cheyenne C20
Offline 78BIG-TEN
« Reply #16 on: June 02, 2015, 09:33:20 am »
Some aftermarket fuel caps wont work.I see this a lot code ,probably the most common
 code set.The canister vent valve usually the culprit,they can also cause the tank hard to
 fill,the gas pump will keep shutting off.Gm has a bulletin out on this
Offline LTZ C20
« Reply #17 on: June 02, 2015, 09:43:28 am »
This is coorrect.
LTZ Cheyenne C20
