Author Topic: 1980 SWB K10 Build  (Read 32002 times)
Offline AZ87V10
Re: 1980 SWB K10 Build
« Reply #15 on: February 14, 2016, 10:40:52 pm »
Good work! It's going to look nice when it's all done! I approve!
Offline bowmank10
« Reply #16 on: February 22, 2016, 10:22:18 pm »
Finished blocking finally, and got everything taped off. Finished painting the bottom of the bed floor
Finally sprayed the blue, took 3 color coats and 1 final. The blue looks really bland without the clear but layed quite well.
 Hopefully finish taping off the white sometime this week and then spraying white and then finally clear this weekend😎
Git R Dun.
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
« Reply #17 on: February 23, 2016, 12:26:09 pm »
Very nice, looking good
 1986 Chevy K30(under repair)
Offline blazer74
« Reply #18 on: February 23, 2016, 01:35:37 pm »
Super!
Offline bowmank10
« Reply #19 on: February 28, 2016, 09:58:21 pm »
Got a lot done on the k10 in the past week.
Finished spraying the white two tone
Here it is with just basecoat sitting outside, the blue really pops
 And after clear coat, the blue and white looks even better than I planned on
Here is how the truck sits all together with her new shoes
Today was the first time I have seen the truck all one complete color and I could be happier with how it turned out. Can't wait to finish it.
Sent from my XT1254 using Tapatalk
Git R Dun.
Offline LTZ C20
« Reply #20 on: February 29, 2016, 03:45:19 pm »
Absolutely gorgeous. Super jealous, excellent paint/body work.
LTZ Cheyenne C20
Offline blazer74
« Reply #21 on: February 29, 2016, 04:53:18 pm »
Wow! X2 on jealous, I'm happily envious of/for U.
Offline philo_beddoe
  • 77 C-10
« Reply #22 on: February 29, 2016, 10:02:30 pm »
Nice two tone!!! Are you keeping the upper and lower trim off and around the wheel wells too? I would like to try that as well.
  • 77 C-10
« Reply #23 on: February 29, 2016, 10:04:54 pm »
I'm more jealous, because thats the paint scheme i was going for, blue/white two tone...no trim!! Dang!!!
Offline bowmank10
« Reply #24 on: March 02, 2016, 03:27:11 pm »
Thanks everyone, a lot of time and money have went into it. Planning on running  full trim (body line, wheel well, back of cab, drip rails).
Git R Dun.
  • 77 C-10
« Reply #25 on: March 04, 2016, 01:41:33 pm »
Couple things:
Does the trim tend to hold water, causing rust rot, etc.
I have been told you have to remove fenders in order to install/remove emblems. Is that right?
Offline bowmank10
« Reply #26 on: March 04, 2016, 05:47:18 pm »
Couple things:
I don't plan on driving the truck during the winter so rust shouldn't be an issue.
I expect the trim will hold water but instead of drilling holes and running screws to attach the trim, I will be using 3m tape.
 For the emblems on the fender I will be finding some newer style Silverado emblems to cover the holes. Any suggestions on such emblems?
Git R Dun.
  • 77 C-10
« Reply #27 on: March 05, 2016, 04:09:57 pm »
Offline LTZ C20
« Reply #28 on: March 05, 2016, 04:17:01 pm »
GM now uses 3M double sides automotive tape for all of its exterior emblems. Works great. No reason at all you can use that.
LTZ Cheyenne C20
  • 77 C-10
« Reply #29 on: March 15, 2016, 05:10:35 pm »
Well, haven't posted in a while, thought I'd take some time and give you folks and update on the K10.
Finally got the bed floor completed
Also finished putting the new bedsides on
Started to put the new interior in
Here is what the truck currently looks like with the new rims and tires
Finished rough blocking the bed and just sprayed the first layer of primer
Hope to have the truck done by March-April
Thanks
Are there any welds on those bed sides, or all bolts, easy to install new ones?
