Author Topic: 1986 Chevy c10 350 running hotter  (Read 9183 times)
Offline pneuner750
Re: 1986 Chevy c10 350 running hotter
« Reply #15 on: July 09, 2015, 03:19:47 pm »
I would ask a pro first.  There pretty cheap however they can screw your radiator up! Hope this helps.
Sent from my SM-P900 using Tapatalk
Offline pneuner750
« Reply #16 on: July 11, 2015, 04:57:17 pm »
BD thanks! I didn't know about radiator caps. Just to a guess. Lol
« Reply #17 on: July 11, 2015, 07:14:37 pm »
You're welcome.
For an additional tidbit... besides functioning as a two-way check valve in the closed cooling system, the radiator pressure cap raises the boiling point of water about 3° F for each pound per square inch of pressure increase above the ambient pressure.  So, a 16 PSI pressure cap will raise the boiling point of water roughly 3°/PSI x 16PSI = 48° F.  At sea level that amounts to 212° + 48° = 260° F for pure water.
But, a 50/50 mix of glycol antifreeze and water boils at about 8° F higher temperature than pure water.  So, at sea level, a 16 PSI pressure cap on the typical automotive wet cooling system that contains a 50/50 mix of antifreeze and water will boil at about 268° F.  That's pretty hot!
In summary, a weak radiator pressure cap won't cause coolant temperature to increase, but it will allow the liquid coolant to boil at a lower temperature than intended, which could expel coolant from the system.  The resulting loss of coolant, if sufficient, will cause overheating.
