Author Topic: Chinese distributor dead, under 5,000 miles  (Read 17946 times)
Offline mcintyrederek
  • Rookie
Re: Chinese distributor dead, under 5,000 miles
« Reply #30 on: July 21, 2015, 03:32:52 pm »
OK that sounds good.  The rotor blade/wiper is straight and clean, not twisted.  On my way now to pick up new cap, dielectric grease, silicone boot and carbon brush.
1986 C-10 Silverado 350 CI 260 HP, Edelbrock 1405, TH400, 2.73's - rescued from the junkyard - Farm Truck, daily driver!
  • Rookie
« Reply #31 on: August 03, 2015, 06:37:21 pm »
Thanks for all the replies and information.  It turned out to be a problem with several different things.  I believe I also had a problem with the hall effect switch and the coil.  I pretty much did a complete tear-down and rebuild of the distributor and it worked great.  I am using a good quality cap and rotor, and Belden plug wires and new AC plugs.  The ignition system is working correctly now.
