Author Topic: Brake picture needed  (Read 33707 times)
Offline Greybeard
Re: Brake picture needed
« Reply #15 on: August 30, 2015, 02:14:23 am »
The 14 bolt on my truck had the adjustment slots on top
We had to drill a slot on the bottom to reach in and back the adjustment off so we could remove the drum
Then it likely wasn't a full floater. All floaters have the adjuster on the bottom (that I have seen anyway, but I haven't seen everything). On a full floater you can't remove just the drum, the entire hub needs to off with the drum. I don't know a thing about a semi-floater though. But since the axle does not need to come out I doubt if the hub needs to come off since there isn't one hahaha. Most drum brake systems have the adjuster on top and slave cylinder on the bottom I believe, the large, heavy duty, full floating axles being the exceptions. But I have been known to be wrong before...
