Author Topic: Mud bog  (Read 32260 times)
Re: Mud bog
« Reply #15 on: September 13, 2015, 02:42:32 pm »
i lied about the engine size. i dont know why i keep thinking its a 8.1 its only a 6.0
Offline fitz
Re: Mud bog
« Reply #16 on: September 13, 2015, 02:51:55 pm »
Quote from: Irish_Alley link=topic=31734.msg266905#msg266905 date=14421652 he wants a cummins or a d-max in it so bad.
[/quote
He should consider a 6.2, I love them. Plenty of power to tow the boat to the lake. You can pull the motor in the parking lot and use it as a anchor for the boat. At the end of the day, reinstall it in the truck & drive home.  Its a very practical motor.
Offline LTZ C20
Re: Mud bog
« Reply #17 on: September 13, 2015, 03:38:49 pm »
Oh my gosh, even worse, they are solid too, but they don't belong in a 1 ton that has to haul around that much weight all the time.
LTZ Cheyenne C20
Re: Mud bog
« Reply #18 on: September 14, 2015, 09:33:17 am »
1st run
https://youtu.be/r-lUel0YWnQ
2nd run
https://youtu.be/ak6J_XmOZtQ
the whole mud bog minus a couple runs. i know my second one didnt make it
https://www.youtube.com/watch?v=16Gu4kBJmUM&feature=youtu.be
« Last Edit: September 15, 2015, 07:08:38 am by Irish_Alley »
Re: Mud bog
« Reply #19 on: September 14, 2015, 10:07:00 pm »
Just curious but can you see the YouTube videos or does it look like the attachment
Offline LTZ C20
Re: Mud bog
« Reply #20 on: September 15, 2015, 02:11:15 am »
1st run
2nd run
[youtube]https://www.youtube.com/watch?v=16Gu4kBJmUM&feature=youtu.be[/youtube]
No videos shown or links available.
LTZ Cheyenne C20
Re: Mud bog
« Reply #21 on: September 15, 2015, 07:09:46 am »
i made it just the links now. i dont know why but i never understood the links
Offline LTZ C20
Re: Mud bog
« Reply #22 on: September 15, 2015, 11:31:21 am »
They are showing now.
LTZ Cheyenne C20
Re: Mud bog
« Reply #23 on: September 17, 2015, 12:58:12 am »
feels like this should be the first picture
even a girl played ;D
even a silly ford played
Re: Mud bog
« Reply #24 on: September 17, 2015, 01:16:49 am »
Offline Don5
Re: Mud bog
« Reply #25 on: September 17, 2015, 01:18:43 am »
Hey Tim the videos worked for me. What happened on the first run? Were you running in 4low and 2nd gear in the second video? It looked like you did not bog down any. What gears are you running also? It looked like a pretty good turn out too. The pics looked really good as well.
Re: Mud bog
« Reply #26 on: September 17, 2015, 01:27:29 am »
the first run i was in 4hi and 2nd gear (counting granny). the second run i was in 4lo and cant remember if i was in 1 (granny) or 2nd want to say 2nd again.
Offline Don5
Re: Mud bog
« Reply #27 on: September 17, 2015, 01:35:25 am »
I thought you would be 2nd gear and running in 4 low. I have the same motor, transmission and transfer case that you are running. I think you are probably geared lower than me since you have a 3/4 ton. I think you are running 38's also right?
Re: Mud bog
« Reply #28 on: September 17, 2015, 01:49:42 am »
4.10. those are 40s. this was my first real mud bog, so im still learning.
Re: Mud bog
« Reply #29 on: September 17, 2015, 02:02:58 am »
so if i was in 4low and 2nd it would have a ratio of 7.01:1
in 4 hi and 2nd i have a ratio of 3.58:1
if i stayed in 4 hi and 1st i would have a ratio of 6.55:1
4low and 1st would be 12.83:1
next time i might try 1st gear its only a little difference than low and 2nd but im going to have to go out and play now
