Author Topic: Grinding sound mystery  (Read 16213 times)
Offline A-Rod
Re: Grinding sound mystery
« Reply #15 on: February 08, 2016, 07:04:06 pm »
I got the same issue but my 87 chevy dose it only on 2 wheel drive. On the front driver side. On 4x4 it drives good with no noise.
A-Rod
Offline blazer74
« Reply #16 on: February 08, 2016, 07:26:56 pm »
Check the rear of the front springs at the shackle, worn bushings can cause the spring to rub the frame just to rule that out. It makes a funky sound that can be misinterpreted.
Offline roundhouse
« Reply #17 on: February 08, 2016, 07:40:18 pm »
Drop the driveshaft and try it
Sounds like a brake caliper moving around or maybe some axles had a shield on the axle shaft that supposed to keep dirt out of the tube  and they sometimes scrape against the tube
