Author Topic: 78 k20 dually bed swap  (Read 13886 times)
Offline roundhouse
Re: 78 k20 dually bed swap
« Reply #15 on: October 30, 2015, 08:07:03 am »
Looks funny with the 3/4 ton wheels in front and dual in back
But it should swap over
Measure the wheelbase of both trucks carefully and take a good look at the frame
Some cab and chassis trucks had a flat frame at the back
Offline Jason S
« Reply #16 on: October 30, 2015, 01:09:13 pm »
Check the overall width of your duals (outer wheel to outer wheel) versus the overall width of the duals on the truck with the dually bed.
If I remember correctly,
With duals swapped onto a single wheel 14-bolt rear end (C/K-20 rear axle), the total width (outer wheel to outer wheel) will be narrower than duals on a dual wheel 14-bolt (C/K-30 dually).
I'm thinking that the dually bed will physically swap fine, but the outer dual on your truck will be set back within the dually fender...
Offline thunderwood78
« Reply #17 on: October 30, 2015, 01:16:45 pm »
I was able to track down the original owner of the truck. It was a standard k20 lwb. He was the one who built the flatbed. Someone afterwards did the dually conversion.
Offline LTZ C20
« Reply #18 on: October 30, 2015, 02:22:56 pm »
Ahhh and that's the ticket right there.
LTZ Cheyenne C20
« Reply #19 on: November 13, 2015, 08:05:05 pm »
so.... are the front wheels bud wheels?
if you look at the back of the rear brake drums is there a lot of room to put a socket and ratchet on the brake bleeder? if theres very little room then this would indicate a cab and chassis rear if theres more than enough room then it would be a dually rear. if you have regular wheels upfront the inside tires should like up if its a dually rear if its a cab and chassis rear the outside tires should line up. take some pictures and we can help tell a story about the truck
