Author Topic: Cutt-off toggle switch.  (Read 37623 times)
Offline roger97338
Re: Cutt-off toggle switch.
« Reply #45 on: December 07, 2015, 09:20:59 pm »
I can bypass the startup wire interrupt with a screwdriver.  So can a thief.
The best wire to interrupt would be the power off the junction block on the firewall or the main 12ga circuit 2 power wire at the starter BAT terminal.  Even if they can start the engine with a wire to the HEI and a screwdriver in the starter terminals the cops will notice no taillights.
The best way to stop a thief is to think like a thief.
Offline philo_beddoe
  • 77 C-10
« Reply #46 on: December 08, 2015, 10:57:35 am »
In the midst of stealing, most thievs are nervous and in a hurry, if the vehicle dont start right away, they are outta there! Sometimes even the e-brake will stop a thief. If i were a thief and the vehicle did not start at the turn of the key, i would not lift the hood and start troubleshooting.
« Reply #47 on: December 10, 2015, 04:18:18 pm »
unless they know youre out of town and they have all the time they need.
  • 77 C-10
« Reply #48 on: December 10, 2015, 10:09:34 pm »
Good point, helps to have watchful neighbors. My cut-off toggle switch idea is just an added layer of protection. Besides, if i am out of town overnight on travel, i unhook the battery. Thats ez to spot, but the toggle will be hidden.
  • 77 C-10
« Reply #49 on: December 12, 2015, 12:04:38 pm »
Should be the 12ga purple wire. If you look at the wiring diagram for 1977 Chevy in Tue tech pages,
http://forum.73-87chevytrucks.com/smforum/index.php?topic=30115.0 , you will see that the solenoid power to the starter is just that. Trace the line in the large diagram at the top of the PDF to make sure but that should be it.
Ok, so if i cut that purple wire the truck wont turn over, right? Somebody tell me before i wreck something. I always get into trouble when i dont know what im doing. Electrical is not my forte'.
  • 77 C-10
« Reply #50 on: December 13, 2015, 03:57:10 pm »
Thats the larger purple wire of the 2 pics right? According to the diagram..
http://forum.73-87chevytrucks.com/smforum/index.php?topic=11766.0
Thats it, i'm cuttin!!! Oh your an angry elf....
Offline frotosride
    • WFO CONCEPTS
« Reply #51 on: December 14, 2015, 09:22:48 pm »
Yes that should be the right one... either way a little heat shrink and solder will fix it back good as new..
  • 77 C-10
« Reply #52 on: December 15, 2015, 03:56:51 pm »
Ok i havnt cut yet, but wire strippers and a nut will put it right back too.  (I feel like im difusing a bomb detonator)
Offline frotosride
    • WFO CONCEPTS
« Reply #53 on: December 21, 2015, 07:10:09 pm »
So did you pull the trigger?
  • 77 C-10
« Reply #54 on: December 21, 2015, 10:07:15 pm »
Oh, not yet. Ya know it's the little jobs we sometimes procrastinate with. Actually i had a mouse problem. But that problem has been "eliminated". Now back to the purple wire. Just need a sunny day above 40.
Offline frotosride
    • WFO CONCEPTS
« Reply #55 on: January 04, 2016, 07:29:57 pm »
Ha good luck with that... Your dirty weather has floated it's way down here it may get just below freezing tonight..
  • 77 C-10
« Reply #56 on: January 04, 2016, 10:07:51 pm »
Yeah froto, your no stranger to maine winters! -5 tonight!!
  • 77 C-10
« Reply #57 on: April 10, 2016, 02:58:24 pm »
Update,,,i cut the big purple wire under there. Turned the key and nothing. Installed on/off toggle switch, fired right up. Just one more level of anti-theft.
Offline Greybeard
« Reply #58 on: April 11, 2016, 12:37:32 pm »
WOW! You get to things as fast as I do! Glad it worked!
I heard a man joke the other day from my wife, she said husbands never forget to do a job they wanted to do, they just need reminded every six months. That's me.  8)
  • 77 C-10
« Reply #59 on: April 11, 2016, 10:04:43 pm »
Lol!!! Ya i think my last post on this job was in Dec. and it took less than 10 min. Idk why we put off some jobs and others we cant get them done fast enough.
