Author Topic: "Custom" Towing Mirrors  (Read 66111 times)
Offline LTZ C20
Re: "Custom" Towing Mirrors
« Reply #45 on: November 22, 2015, 09:54:17 pm »
Looking at this and how the things slide off why not put a small cable attaching the mirror head through the arm and down to the base. That way if you did pull to far or they tried to slide off the cable would catch it and go nowhere.
You must have missed the part where I mentioned the arms on these are SOLID bar stock. The mounting holes where drilled and taped to accept the bolts for the original way they are mounted. If the bars where hollow I would have run wires thru them and made them heated and have turn signals.
LTZ Cheyenne C20
