Author Topic: exhaust recommendations  (Read 18914 times)
Offline BBM3
Re: exhaust recommendations
« Reply #15 on: November 15, 2015, 06:16:46 pm »
Use band clamps and if needed you will be able to disassemble / reassemble the exhaust system at-will in minutes.
Offline travisr1988
« Reply #16 on: November 15, 2015, 11:28:35 pm »
If you want quiet locate the muffler as far back as possible and install a crossover, I ran the exhaust temporarily until I could get it on a lift and had the mufflers under the cab and dumped just before the rear wheels and it was way too loud in the cab, now I have a crossover just after the transmission crossmember and mufflers located just behind the cab with 90s behind the rear tires. Now when we built this on a lift we left out the crossover due to time constraints and added it next day, and it was noticably quieter with the crossover. I used the dynomax kit for our trucks (2.25") but had to modify it to work with my headers and I used thrush welded mufflers.
1979 Chevrolet Silverado C20 rclb cammed 355/th400/4.10 - sold
1977 Chevrolet Custom Deluxe c10 rcsb stepside 355/th350/3.42
Vortec heads lunati cam edelbrock intake headers
