Author Topic: Brooke's 87 V10  (Read 246893 times)
Offline Captain Swampy
  • Wisconsin
Re: Brooke's 87 V10
« Reply #30 on: December 14, 2015, 10:23:16 pm »
The frame wasn't broke, but we added the brace for the steering box so it won't crack. I think it will interfere with the bumper support when we try to put it back on. The outer rocker was wide, so I made a cut on the yellow line. Looked good after welding back together. The lower cowl patch is welded in also.
  • Wisconsin
Re: Brooke's 87 V10
« Reply #31 on: December 14, 2015, 10:38:02 pm »
The engine doesn't have a lot of miles, but sat for about 12 years. It's burning some oil. Any suggestions? I'm guessing rings are stuck. She's been driving it since August. Was told to try Restore. We're running 5W40 Amsoil.
Offline Engineer
Re: Brooke's 87 V10
« Reply #32 on: December 15, 2015, 06:26:23 am »
Try finding OE doors, hood, and fenders from a 1988~1991 Blazer or Suburban. They are galvanized and resist rust better than the steel up to 1987.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
Re: Brooke's 87 V10
« Reply #33 on: December 15, 2015, 11:40:36 am »
To paint inside rockers and such, Eastwood sells a product called internal frame paint. I won't vouch for it(never used it) but the wand extension it comes with can be used on aerosol cans. You can also do a search on Google for aerosol can extensions with a 360 degree spray pattern
Sent from my LGL34C using Tapatalk
 1986 Chevy K30(under repair)
Offline philo_beddoe
  • 77 C-10
Re: Brooke's 87 V10
« Reply #34 on: December 15, 2015, 03:59:31 pm »
It also looks like someone is goofing off a little while someone else is doing all the work. Haha
Re: Brooke's 87 V10
« Reply #35 on: December 18, 2015, 07:15:39 am »
im usually the one goofing off if i can get someone else to do the work also lol.
  • Wisconsin
Re: Brooke's 87 V10
« Reply #36 on: December 18, 2015, 11:00:42 am »
True story, I try to avoid the camera when goofing off. Brooke probably has a few though. She's been reading this, I'm surprised she hasn't jumped in with some comments yet.
  • Wisconsin
Re: Brooke's 87 V10
« Reply #37 on: December 18, 2015, 11:44:24 am »
Just to prove she worked very hard on her pickup.
  • Wisconsin
Re: Brooke's 87 V10
« Reply #38 on: December 18, 2015, 12:02:57 pm »
We cut holes so we can wash out behind the inner rockers. Painted rockers with POR before we welded the outer on. Lots of spaghetti, scotch locks, and stripped wire with a wire twisted around it covered with electrical tape.
  • 77 C-10
Re: Brooke's 87 V10
« Reply #39 on: December 18, 2015, 06:50:55 pm »
Looks like someone's got some wiring to do. But coming along nice!
  • Wisconsin
Re: Brooke's 87 V10
« Reply #40 on: December 19, 2015, 12:16:27 pm »
We used the front clip and engine harnesses from our suburban. Most of the stuff inside, we could remove the garbage and fix with a heat shrink butt connector.
  • Wisconsin
Re: Brooke's 87 V10
« Reply #41 on: December 19, 2015, 01:03:05 pm »
We did have fun though! Brooke has a great sense of humor. Put new spider gears in it. It has a 12 bolt swapped in. When we put the axle shafts in the drivers side had gunk on the end so we pulled the carrier and found this mess. I almost talked myself into running it a month and then changing the oil. Thank God for that nagging feeling that wouldn't let me do that!
  • Wisconsin
Re: Brooke's 87 V10
« Reply #42 on: December 19, 2015, 01:31:14 pm »
Not sure where the pictures of the finished metal work went. Here's starting to finish it.
  • Wisconsin
Re: Brooke's 87 V10
« Reply #43 on: December 19, 2015, 01:34:13 pm »
We started a lot of other stuff once the hole in the floor was gone and the under side of the cab painted.
  • Wisconsin
Re: Brooke's 87 V10
« Reply #44 on: December 19, 2015, 01:35:42 pm »
 8)
