Author Topic: Tranny dripping from front U joint  (Read 20054 times)
Offline philo_beddoe
  • 77 C-10
Re: Tranny dripping from front U joint
« Reply #30 on: March 14, 2016, 10:12:59 pm »
Can you crow bar the pipe down enough to jam a wooden shim in it to separate it from the frame enough to see if it makes a difference?
I thought of that, and now that you mention it, i think i can shim a piece of wood in there, its not so hot it will cook the wood now...will it?
« Reply #31 on: March 14, 2016, 10:15:59 pm »
shouldn't, you should know right away if that is the route cause.  Let us know
  • 77 C-10
« Reply #32 on: March 14, 2016, 10:18:48 pm »
Will do, gonna try it first thing in the am. I figure when i put the H pipe in there i'll set it correctly away from that cross member.
« Reply #33 on: March 14, 2016, 10:31:57 pm »
good plan
  • 77 C-10
« Reply #34 on: March 15, 2016, 04:53:20 pm »
I didnt have to put a shim in there, i used the tire iron from my f-350 and pryed it down just a tad, enough not to touch the crossmember. We'll see how it is when i leave for work in the morning.
Also, its been a couple days and not one single drop from the peep hole, i mean weep hole.
« Last Edit: March 15, 2016, 05:06:09 pm by philo_beddoe »
Offline LTZ C20
« Reply #35 on: March 15, 2016, 07:23:48 pm »
Peep hole.... lol
LTZ Cheyenne C20
