Author Topic: AC/Delco EP381 Diesel fuel compatability?  (Read 32374 times)
Offline big_al273
Re: AC/Delco EP381 Diesel fuel compatability?
« Reply #15 on: April 21, 2016, 04:38:25 pm »
the P7100 needs more fuel supply than a ve, the lift pump actually helps feed the piston in the ppump, the ve and vp44 both have internal pumps that will pull fuel in the event of a lift pump failure but they are weak at best. some 24v cams do infact have the lift pump lobe. the block mounted lift pump is good for about 500hp. the reason so many people go to an electric lift pump is the flow is stable and the pressure can be adjusted to feed correctly.
Ok another question, is there any issue with having 30-40 psi of fuel at idle? what about 60 psi of fuel at idle? the P7100 injection pump has a fuel return, correct?
91 Chevy R3500 Crewcab future project
89 GMC R3500 Cab & Chassis Tool truck project
88 Chevy V30 Crewcab Ex-firetruck
87 Chevy R20 Crewcab future project
84 Chevy C10 Suburban Project
84 GMC K1500 winter beater
Offline big_al273
« Reply #16 on: June 09, 2016, 01:25:10 pm »
Anyone have anything on this subject since Bajaburban can't be bothered?
« Reply #17 on: June 09, 2016, 02:54:26 pm »
did you pm him? or check out his facebook under his profile?
