Author Topic: 4x4 shifter assembly  (Read 8356 times)
Offline Pike1915
  • Trying to kept my sanity
Re: 4x4 shifter assembly
« Reply #15 on: April 09, 2016, 11:01:28 pm »
I put the part back into my truck, stuck a bolt in to make sure the plates where in neutral when I snugged everything up.. ran through the gears and everything seems to be working just fine..  will have to do a major road test to double check but so far so go.
Thanks for all the help ...
« Reply #16 on: April 10, 2016, 07:04:18 am »
im guessing but i would bet that the two arms are supposed to move at different lengths. if they should be the same movement then why even have two arms?
this is how people turn the 203 into a double stick ones for front wheels while the other is for low/hi
