Author Topic: Anti Theft  (Read 18409 times)
Offline Fulltimechevy89
Re: Anti Theft
« Reply #15 on: May 27, 2016, 06:40:14 pm »
Not that I know of. You do have to put in a new sim card and add minutes, I was able to get $10.00 worth for 100 texts. it lasts a while for me, maybe $10.00 a month at the very most. Basically it's a phone with a tracker in it
Re: Anti Theft
« Reply #16 on: May 27, 2016, 07:19:43 pm »
when do you get a text only when you request one?
Offline Militiaman55
  • 74 K10 Cheyenne
Re: Anti Theft
« Reply #17 on: May 29, 2016, 12:53:39 am »
My truck is so dang hard to cold start, I'm hoping that discourages them enough to move on.
Offline philo_beddoe
  • 77 C-10
Re: Anti Theft
« Reply #18 on: May 29, 2016, 06:30:24 am »
Lol!!!!
Re: Anti Theft
« Reply #19 on: June 03, 2016, 07:06:27 pm »
It only responds to texts when you send one first
Re: Anti Theft
« Reply #20 on: June 03, 2016, 10:11:54 pm »
so $10 for 100 text. how many times do you plan on pinging your truck to find it? im confused as to why you would need this many. i would only want 5 and only use it if my truck was MIA.
Offline berserk
Re: Anti Theft
« Reply #21 on: June 07, 2016, 04:05:31 am »
Well first my truck has a manual choke and most non car guys under 40 don't know how to use it and if it is below 60 out good luck starting it without the choke.
I also have an ignition kill switch on the dash, its in the open but originally I planned on 2 more for dummy switches then mislabeling them. I also run a batt cut off that is hidden between the core support and grill. You have to stick your arm up under the bumper and between those two to find it, It has a removable "key" so with out it there good luck.
I also used to run a chain to lock the hood down, it went through a hole in the core support and wrapped around the frame with a lock. But it was a pain to check oil etc and in case of emergency with the engine I didn't want to worry about having to unlock it.
76 Chevy k10 350/th350/203 part time. Vortec head 350 Dana 60 w/Detroit, 14 bolt Tru Trac, 33" Micky T. Mudders.
  • 77 C-10
Re: Anti Theft
« Reply #22 on: June 07, 2016, 09:24:49 pm »
No worries there. I saw a guy at a car show with a battery cut off switch mounted right at the battery post. Not many thieves will look under the hood to see whats wrong.
Offline Ludwig Von 88
  • Mad world.
Re: Anti Theft
« Reply #24 on: August 11, 2016, 05:46:30 am »
No one steal that kind of car in my country, only a few peoples know how to drive it and nearly impossible to sell also for parts. There it's an Alien...
Ludwig Von 88
1980 Chevy Suburban C20 3/4 ton Scottsdale.
