Author Topic: C10 drop  (Read 18278 times)
Offline Est.1996
Re: C10 drop
« Reply #15 on: May 14, 2016, 01:37:13 pm »
I don't want to do the 4/6 because i don't want to do a c-notch and affect ride quality  since its my daily right now
Offline SILV
Re: C10 drop
« Reply #16 on: May 14, 2016, 10:20:36 pm »
It's hard to tell by the angle but it looks like you shouldn't have an issue with a 2/4 drop.
Sent from my SM-G925R7 using Tapatalk
Offline Est.1996
Re: C10 drop
« Reply #17 on: May 16, 2016, 03:26:40 pm »
Here's more pics I took. The front look to me like they will rub but the rear look like it'll be ok. Thank you guys for the input.
Offline Est.1996
Re: C10 drop
« Reply #18 on: May 17, 2016, 01:34:12 am »
It depends on what the width and offset of the wheel is. If it has too much negative offset it will be too close to the fender lip. Do you know the specs on those 22's?
Found the specs....22"x9.5 with +18 offset
Offline SILV
Re: C10 drop
« Reply #19 on: May 17, 2016, 11:49:42 am »
If I did the math right you will have no problem running those wheels with a 2/4 drop.
