Author Topic: Want to Learn More About Bumper & Hitch  (Read 16555 times)
Re: Want to Learn More About Bumper & Hitch
« Reply #15 on: May 18, 2016, 01:35:35 pm »
found them for the blazer and burb
Offline LTZ C20
« Reply #16 on: May 18, 2016, 02:34:41 pm »
This is all really good. I will agree that the info in Irish's post #9, everything from the dashed line up should be added to the tech section where you started your GVWR/GCWR post.
My truck had a 350, TH350 and 4:10 new. Now it has a beefy 350, beefy 700R4, and 4:10. The hitch only has bolts holding it to the frame, everything else is fully welded. My best guess is it most likely is a Class 4 hitch, an older one because it's a 2 inch receiver. I'm considering removing it to look for more info that may be on it where I can't see. The bolts are pretty large as you can see. The rust is only surface stuff, it would come right off if i wanted to sand and paint it.
I know that new, with eng/trans/rear-end/tire cap/spring cap, the GVWR is 8200lbs. Well now, with the stronger eng/trans/tires, the HD springs I put up front and the new HD springs I'm going to put in back, the GVWR will be substantially higher. I have always trusted it, maybe someday I'll get something heavier duty. I do want to get one of those gooseneck/5th wheel combo hitches.
« Last Edit: May 18, 2016, 03:01:12 pm by LTZ C20 »
LTZ Cheyenne C20
Offline 75gmck25
« Reply #17 on: September 17, 2016, 10:38:44 am »
In that era it was very common for trucks to be delivered to the dealer with no back bumper, even if it was a factory option.  Most  dealers ordered pickup trucks without rear bumpers, since that gave them more flexibility to install whatever the customer wanted.
Bruce
Offline AZ4X4SQBDY
1987 GMC Sierra Classic 4x4 short, fleet, 1985 Chevrolet Silverado 4x4 short, step side, '87 Chevy Silverado short fleet, '91 Dodge Ramcharger LE 4x4,
2005 Porsche Boxster S,1982 Alfa Romeo Spider Veloce
