Author Topic: Manual trans trouble  (Read 15856 times)
Offline hatzie
Re: Manual trans trouble
« Reply #15 on: August 04, 2016, 04:48:22 am »
There's no spring on the pedal.
#11 from the frame to the fork. 326582 Clutch Fork Pull Back Spring
#19 from the frame to the pushrod pivot. 330112 Pushrod Retainer Spring
Even without the return springs the pedal shouldn't drop to the floor.
Is the pushrod from the pedal to the Z-Bar damaged or out of the pivots?  The push rod is #1 in the pedal blowup on the below page.
« Last Edit: August 04, 2016, 05:11:24 am by hatzie »
