Author Topic: 86' C10 Passenger Power Window Wiring  (Read 68398 times)
Offline MichaelSnapper
  • Getting Better
Re: 86' C10 Passenger Power Window Wiring
« Reply #15 on: July 29, 2016, 08:24:41 am »
Looks like I'll be busy for awhile. I don't have a meter. Do you recommend any? Am I for now able to take a jumper wire & run it from door to door, wire to wire (Tan & Blue w/wht stripe) to see if there is a break? Thank you!
« Reply #16 on: July 29, 2016, 09:57:35 am »
Use an incandescent (analog) test light, they're effective and cheaper.  Candidly, if you have time to string wire you have time to figure out, at least, which wire is causing the problem.
  • Getting Better
« Reply #17 on: July 30, 2016, 10:50:08 am »
Ok, I took a test light and did as you said. Only wire that would light up/show hot was the Pink.
p.s. I had ignition key to on position.
« Reply #18 on: July 30, 2016, 11:04:04 am »
Repeat the test at the left door switch (dark blue/white and tan) with the wires connected to the switch.  What happens?
  • Getting Better
« Reply #19 on: July 30, 2016, 11:14:23 am »
Same thing, except divers window shows hot.
« Reply #20 on: July 30, 2016, 11:48:57 am »
What do you mean?  If you are saying the left window rolls up and down just fine, but the blue/white and tan wires at the left switch never become hot when flipping the switch in either direction, replace the left window switch.
In the meantime, with the left switch plugged in and the right switch unplugged, ignition on, connect your test light between the pink and tan wires and then the pink and blue/white wires at the right window switch connector.  If the test light illuminates in both cases, the wires running to the opposite door have continuity.
  • Getting Better
« Reply #21 on: July 30, 2016, 12:00:28 pm »
The pink & tan light up.
The pink & blue/wht does not light up.
  • Getting Better
« Reply #22 on: July 30, 2016, 01:03:46 pm »
Still switch?
« Reply #23 on: July 30, 2016, 01:32:32 pm »
Still switch?
If I'm tracking with you and you were checking at the passenger side window switch connector, there is an open in the blue/white circuit - meaning either in the wire (which includes the in-line connector behind the dash) or the left door switch or both the wire and the switch.  To narrow the culprit further, unplug the left door switch and jumper the blue/white wire in the left door to a good ground.  Check for continuity using your test light across the pink and blue/white wires in the right door as you did before.  If the test light illuminates, replace the switch.  If not, start tracing the blue/white wire through the cab, focusing on the in-line connector and where the wires pass through the jambs.
  • Getting Better
« Reply #24 on: July 30, 2016, 01:42:29 pm »
It lit up, ordering switch now.
  • Getting Better
« Reply #25 on: July 30, 2016, 03:36:27 pm »
Okay! A smile upon my face. Got new switch, both sides working again. I am so Thankful for ALL your Time, Help & Consideration! Take Care, Be Safe!
« Reply #26 on: July 30, 2016, 04:31:55 pm »
You're welcome!
  • Getting Better
« Reply #27 on: July 30, 2016, 05:00:37 pm »
p.s. Thx for the education!
