Author Topic: Brought my high school 78 bonanza back to life  (Read 26841 times)
Offline redhot1.4
Re: Brought my high school 78 bonanza back to life
« Reply #30 on: December 23, 2016, 03:09:51 am »
Those lamps appear rotated 90°.  Looking forward to the nighttime pics.
Yeah these are definitely different lights
I put them in were I thought was the right way& then found my self rotating them again
Sent from my SAMSUNG-SM-G870A using Tapatalk
Offline Mark16B
« Reply #31 on: December 23, 2016, 08:05:35 pm »
Man that is sweet, you definitely just gave me motivation to continue on my Silverado. Yours looks like a Cadillac compared to my old beater
Offline redhot1.4
« Reply #32 on: December 24, 2016, 09:12:22 am »
I need to find my old pictures before I ever started. I've had this truck since I was 15, I'm 32 now , and I've been on and off with this Ole truck . I got repainted when I was 23 , this guy painted it 4 times and still failed.  Long story there, but just by a part at a time. There pretty cheap versus the newer trucks
Thanks
Offline redhot1.4
« Reply #33 on: January 05, 2017, 05:17:23 pm »
Well I had to do another ujoint job, I should have replaced the front 1 when I did the carrier bearing. But It didn't show anywear and tear. Boy did that change quick, truck was shaking very bad ,
I was planning on having my new cowl induction hood and a-c by spring but life happens when you don't expect it to, I'll keep going tho, just delayed a little
Offline redhot1.4
« Reply #34 on: May 07, 2017, 07:54:24 am »
Well guys it's been a while since I've posted anything,been extremely busy with life. Anyways I bought my new 2 & half inch cowl induction hood Friday going to pick it up Monday because this happened again,, Its replacement
I've got the Itch again to put a little more cash in the old truck again.  If anyone has any advice on how to NOT BEND THIS HOOD I would appreciate any information,, see yall Monday with pictures
« Reply #35 on: May 07, 2017, 09:02:37 am »
lube your hinges or youll bend your new one also. and if you have the money replace the hinges, ive re-enforced the area of my truck where they bend but this is a major safety issue cause if you hit something the hood could come back and decapitate you. my truck i did it to is my mud truck so thats no much of an issue
Offline redhot1.4
« Reply #36 on: May 09, 2017, 08:28:47 am »
Well I like it for sure. Now all I see is all the other parts I need to buy to complete it. The hood still vibrates going down the road. I'm told i need billet hinges .
Offline redhot1.4
« Reply #37 on: June 11, 2017, 12:17:55 am »
Well I needed to do a little maintenance on my 78. My plan was replace the blinker  mechanism behind the steering wheel and the blinker lever and a motor mount.  I ended up replacing the transmission mount, and Val cover gaskets.  I did get to fix the blinker problem because I didn't have that decompression tool . Those motor mounts are a pain by your self not having ever don't it before  here are some pics.  There was absolutely no rubber left on the motor mount. Lol
But I replaced it.. tranny mount was shoot too.. I still have this shutter when taking off. Thats why I replaced everything ,,last but  not for long lol
Next up steering gear box. Anybody have any tips on replacing those.. ???
Offline roundhouse
« Reply #38 on: June 12, 2017, 06:06:27 am »
I've never done a box
Only advice I got for the steering box is Install a brace on the frame
Nice looking truck
Gonna need AC in Texas for sure
Fixing to buy a Vintage Air kit for mine
You can find the older 700r that doesn't need any electronics to run
Not sure what years to look for though
Early 80s but I don't know exactly
If you really get brave you could tackle a LS swap
I did and
That's a lot more power but don't think it's any better MPG
« Last Edit: June 12, 2017, 06:13:56 am by roundhouse »
Offline redhot1.4
« Reply #39 on: June 12, 2017, 12:55:42 pm »
Nice looking truck
I did and
Thanks.  Yes ac would be nice. I had planed on it alot sooner. I need to knock out that new steering box then the ac
I plan on getting a quote on my ac
I have everything other than the compresser and a bracket
Offline redhot1.4
« Reply #40 on: July 05, 2017, 12:47:29 am »
Yeah some packages arrived today should have a couple more in a few weeks getting close to having my A/C  fixed
« Last Edit: July 05, 2017, 01:23:26 am by Irish_Alley »
Offline redhot1.4
« Reply #41 on: July 17, 2017, 03:14:26 pm »
FINALLY tackled the turn signal switch.  That switch has a plastic sleeve protection cover that's bolted down by the steering column , that was the biggest problem,  until I figured that out, next would be that lock plate ring. Other than that my turn signal switch is all new including the lever, works great
I forgot, i accidentally ordered a canceling cam replace it to. It's on a 10 part
Offline redhot1.4
« Reply #42 on: July 20, 2017, 08:12:46 pm »
Got around to putting the new mirrors on.  The sport mirrors are kool, but not very useful,  and my was old and faded and wouldn't hold a position
Out with the old , in with the new
