Author Topic: 73-87 Chevy vs Gen 1 Dodge  (Read 11353 times)
Offline AZ4X4SQBDY
Re: 73-87 Chevy vs Gen 1 Dodge
« Reply #15 on: October 23, 2016, 07:55:32 am »
i just think GM is better designed than not only Mopar, but Ford as well.  The fact that i grew up in a GM family is merely a convenient coincidence.  :)
It's interesting to note that some of those mopar trucks came with quadrajets.  Not sure exactly which years but i think mid 80's?
Ford also used the Quadrajet on high performance engines during the late '60's
1987 GMC Sierra Classic 4x4 short, fleet, 1985 Chevrolet Silverado 4x4 short, step side, '87 Chevy Silverado short fleet, '91 Dodge Ramcharger LE 4x4,
2005 Porsche Boxster S,1982 Alfa Romeo Spider Veloce
Offline hatzie
« Reply #16 on: October 24, 2016, 08:37:27 am »
Sat too long with antifreeze on top of the piston, rusted the cylinder bore deeper than boring it .060 would clean up, didn't want to get into sleeving it.
I didn't expect that because I too thought 318 were stout motors. The guy let it sit for almost a year because he got busy with work and it was a difficult job with a 4" lift and 33" tires.
Dang.  The engine was probably otherwise just fine til he did that.
If I have a head gasket leak that I can't get to I pull the lower rad hose and crank the engine with no spark plugs to drop the coolant level below the deck and blow the coolant out of the cylinders.  Drain and fill the crankcase with some cheapo 10W oil with a fresh Walmart filter then add a tablespoon of ATF each in all 6 or 8 cylinder and a second good crank.  Then just re-install the plugs finger tight.  No rusting cylinders and no cruddy oil in the bearings...
« Last Edit: October 24, 2016, 08:39:03 am by hatzie »
