Author Topic: 82 c10 5.3l swap questions  (Read 22881 times)
Offline Gagecampbell82
Re: 82 c10 5.3l swap questions
« Reply #15 on: December 31, 2016, 12:26:24 pm »
Awesome! Thanks for the info. I'm considering having team208 do my harness. I believe I can do the work but I don't have much free time. I have ordered headers, adapter pipes, and mounts from holley.
The next thing I will order is the flywheel adapter. I will be running a th350 I've read I could use a spacer on the hub of the converter and elongate the holes on the stock 5.3 dished flywheel. But I found a flywheel from advance adapters that has a spacer for the flywheel with longer bolts and I'm curious what everyone has used. I'd like to one day upgrade to a th400. It will be a performance based build so I want to use what will hold up to higher power one day.
I'm also curious if a th350 and th400 use the same converter bolt pattern so I could buy one flywheel and use it when I upgrade the trans in a couple years. Or weather I'll have to buy another.
1982 Chevy c-10 Scottsdale, 350/TH350
« Reply #16 on: January 08, 2017, 03:00:47 pm »
TH350 and TH400 use different flywheels.
« Reply #17 on: January 08, 2017, 10:20:35 pm »
Thanks, I thought they did but I wasn't sure. I ordered the kit from advance adapters for a th350 a couple days ago. Should be here Tuesday. Hoping they send me the right one.
