Author Topic: Where does the positive on the choke connect?  (Read 32964 times)
Offline 82silverado
Re: Where does the positive on the choke connect?
« Reply #45 on: January 03, 2017, 09:16:06 am »
Choke is 20 amp.
82 Silverado 454/700R4
86 Buick GN
02 WS6
Offline Stewart G Griffin
« Reply #46 on: January 04, 2017, 09:23:46 pm »
Ok, i just looked at the fuse panel and it does say 20A for the choke slot.
It does seem rather high, and i would think 5A should be enough, you know just to power the choke coil, but there you have it.
Offline m3talc0re
    • Burning Concept
« Reply #47 on: January 05, 2017, 12:17:36 pm »
Lol. Learn something new every day, huh?
Offline m3talc0re
    • Burning Concept
« Reply #48 on: February 01, 2017, 03:40:54 pm »
Does this help sort out the confusion on circuit operation?
I just realized I didn't thank you for the post. Yes it did clear up my confusion. I just came back to this thread because I'm about to go wire it up, lol.
« Reply #49 on: February 01, 2017, 04:18:45 pm »
You're welcome.  Good luck with it.
Offline m3talc0re
    • Burning Concept
« Reply #50 on: February 03, 2017, 01:26:51 am »
I  got it all connected right I think. But it's not working properly. When I start it, the choke light is only on for a second or two. The choke never relaxes.
« Last Edit: February 03, 2017, 02:54:36 am by m3talc0re »
« Reply #51 on: February 03, 2017, 09:22:10 am »
The choke light is operating normally.  It is supposed to extinguish when engine oil pressure builds above 3 - 7 PSI.
Use a test light grounded directly to battery negative to probe for power at the choke thermostat while the engine is running.  If there is no power, the choke is incorrectly wired.  Recheck your work.
Once you have verified power to the t-stat, shut off the engine and disconnect the choke lead.  Jump B+ directly to the choke t-stat terminal.  The choke plate should gradually open all the way over the ensuing 2 - 3 minutes, max.
If the choke doesn't open, either the t-stat is faulty or it is not grounded.  Make sure there isn't a gasket installed between the choke t-stat and its housing, insulating the t-stat from ground.  With B+ still connected to the t-stat, probe the t-stat housing to make sure the test light doesn't glow.  If the test light glows even slightly, the choke housing is not properly grounded through the carburetor to the intake manifold.  Replace the t-stat and/or correct the ground connections as testing indicates.
Offline m3talc0re
    • Burning Concept
« Reply #52 on: February 04, 2017, 03:24:07 am »
How long should it take to get 3 to 7 psi?
Offline 82silverado
« Reply #53 on: February 04, 2017, 07:27:39 am »
After it starts, just a second or so.
86 Buick GN
02 WS6
Offline m3talc0re
    • Burning Concept
« Reply #54 on: February 04, 2017, 08:28:34 pm »
I checked it with a multimeter earlier and it's getting power. But it doesn't seem to want to open right. I'm wondering if the coil or something is just worn out
« Reply #55 on: February 04, 2017, 08:34:25 pm »
Did you jump power directly to the choke t-stat and verify there is no gasket between the t-stat cover and its housing?
Offline m3talc0re
    • Burning Concept
« Reply #56 on: February 04, 2017, 10:14:07 pm »
I verified power and ground on the choke terminals
« Reply #57 on: February 05, 2017, 09:00:44 am »
Replace the choke thermostat.
