Author Topic: 1984 GMC K10 Build  (Read 79262 times)
Offline GMCMedic
Re: 1984 GMC K10 Build
« Reply #120 on: June 24, 2017, 06:10:24 pm »
I uploaded everything to one photobucket album. I dont use it much cause of tapatalk, so once i figure out how to link a whole album i will.
Sent from my SAMSUNG-SM-G920A using Tapatalk
Offline GMCMedic
« Reply #121 on: June 25, 2017, 09:11:04 am »
This should work....maybe
http://s738.photobucket.com/user/Robert_Mabrey/library/84%20k10%20Project
Offline GMCMedic
« Reply #122 on: July 23, 2017, 07:18:36 pm »
Its been a mostly uneventful 700 miles so far. Gas mileage seems to be improving but its been harder to check lately cause ive been filling gas cans out of state to top of the truck (save $5 on every fill up just with the truck).
The other morning the steering seemed tight pulling into the driveway. I got out and the gear box was leaking power steering fluid. Im not mad, I didnt replace it so it was likely original. A few hours in the heat and the power steering was fixed.
Something is up with the drivers side tank. I had to solder a ground onto the sending unit and run it to the frame. The gauge will work intermittently if I fiddle with the wire. I cleaned up the contact on the frame but it didnt fix it. Its to much work to drop the tank so ill keep fiddling with it as needed.
And the front passenger side parking light burned out already. Probably cause i bought cheap amazon LEDs. Ill upgrade it but its too hot to pull the grill off right now.
Offline jptiger
  • Husband of Kim father of Joshua
« Reply #123 on: February 07, 2018, 08:25:44 pm »
Sweet ride brother!
1977 GMC Sierra Grande K15 swb
1992 GMC Sierra K1500 ext cab
