Author Topic: 87 Chevy crew cab build Ls swap with lots of pics  (Read 250622 times)
Offline copperhead629
Re: 87 Chevy crew cab build
« Reply #15 on: January 17, 2017, 09:14:09 pm »
HWH- Awesome build and keep the pics coming. I love the LS motor swap and Blazer tank in rear !!
I live in Texas also and l searched for a couple of years before finding a 1991 V3500 crew cab about 6 months ago.  Its a factory stock truck with a big block and power windows and ice cold air. The truck is super low mileage, but spent its entire life on a ranch. So far I have installed 6 inch front lift, new bearing and u-joints in front D60, pulled motor and installed new oil pan gasket and intake manifold gasket, motor mounts, Hooker headers, 3 inch duals with flows, tranny cooler and completely rebuilt wiring harness.  I've got a 4 inch shackle flip for the rear and a suburban interior ready to go in as well The only beat- down is this truck has a Gen V 454 with TBI and I don't have a lot options to build power.
I have owned 2 other square body crews, one with 12 inches of lift and 40's and one with 15 inches and 44's.  This will be a driver with 6 inch and 35/36's.
Offline hwh
« Reply #16 on: January 18, 2017, 07:12:55 am »
Nice copperhead. You have the holy grail truck 1991 was only year had 4l80e to np205. Everyone wants that adapter lol. Luckily I had the round pattern np205 and not figure 8 so made it easier to adapt got my adapter from northwest fab. And yea when I bought truck had 350 TBI. And did a lot of searching and there's not a whole to do to get a lot more power out of the TBI motors. But hey we all got to start somewhere. When I first started this build I was going to do the Cummins swap but more research decided not to. I just think in the long run ill be happier with ls swap. I'll get more pics soon posted I have been taking pics every little step.
Offline hwh
« Reply #17 on: January 21, 2017, 08:11:29 am »
lots more pics. first few are truck when i bought it. it was a descent truck but wasnt the look i was going for. ist had 6 inch lift with 3 inch body lift. 38 tsl swampers.
« Last Edit: February 14, 2017, 08:21:56 am by hwh »
Offline hwh
« Reply #18 on: January 21, 2017, 08:14:37 am »
shortbed pics
Offline hwh
« Reply #19 on: January 21, 2017, 08:19:58 am »
everything was cleaned and painted. pics of dana 60 and gm 14 bolt rebuilt all new parts. and suspension lift going in. i used offroad design 4 inch shackle flip in rear with stock new springs. and 4 inch tuff country hd springs in front.
Offline hwh
« Reply #20 on: January 21, 2017, 08:25:10 am »
axles are installed some pics of crossover steering arm and brakel line kit for the rear from offroad design
Offline hwh
« Reply #21 on: January 21, 2017, 08:28:52 am »
did alittle sanding and got all fuel lines ran and feul pump in tank. and pics of fuel filter mounted. i used gf822 fuel filter and ep381 fuel pump for the ls swap.
Offline hwh
« Reply #22 on: January 21, 2017, 08:36:07 am »
got master cylinder and hydrobboost replaced ran all new brake lines front and rear with wilwood valve. more sanding and painting replaced strikers on doors and replaced hinge pins and front door springs on top hinges went this route so still atleast have orginal hinges. got my steering column back from guy who rebuilt it got it installed real happy with it. also went to dealership and bought cooland bottle for 6.0 motor so looks more factory.
« Last Edit: January 21, 2017, 08:50:42 am by hwh »
Offline hwh
« Reply #23 on: January 21, 2017, 08:39:32 am »
these pics are out of order but here are some of stripping it down to frame. i sold all old parts and put money back in to it
Offline hwh
« Reply #24 on: January 21, 2017, 08:43:13 am »
got it stripped down ready to clean and paint got axles off and a pic of np205 its the round adapter one.
Offline hwh
« Reply #25 on: January 21, 2017, 08:46:17 am »
started cleaning frame, axles, and bottom of bed and painting
Offline hwh
« Reply #26 on: January 21, 2017, 08:49:12 am »
Offline hwh
« Reply #27 on: January 21, 2017, 08:55:21 am »
ill get lots more pics posted where i left off in post above. but here are some as what stage im on now getting ls swap and painless wiring harness. High mount brackets used for a/c compressor to move from bottom to top of motor. Headers worked out nice clearance from frame which is good. Saw people notching there frames to fit others. Didn't want to do that. Got porcelain spark plug wires to help from heat from headers.
« Last Edit: January 21, 2017, 09:22:39 am by hwh »
Offline hwh
« Reply #28 on: January 21, 2017, 08:56:56 am »
pics
Offline hwh
« Reply #29 on: January 21, 2017, 08:58:05 am »
vintage air going in also soon and driveshafts
