Author Topic: rebuild  (Read 23342 times)
Offline impco lpg
Re: rebuild
« Reply #15 on: August 20, 2017, 07:43:21 am »
just fitted new door handles and wing mirrors, outside is about complete. when I bought the stainless steel grill they don't do a grill emblem. so I have made my own, out of some polished stainless. turned out sweet.
1983 cucv m1009  blazer 6.2 4x4
1991 1500 suburban 5.7 4x4 lpg
2003 dodge ram 5.7 4x4 lpg
1985 chevy c10 stepside  2wd 5.7ltr 350 lpg
Offline impco lpg
Re: rebuild
« Reply #16 on: November 12, 2017, 08:51:22 am »
I ordered my carpet  two months ago and it arrived but was the wrong colour BLUE  :(, I ordered BLACK. so still waiting.
so I have finished all the sound deadening and some rewiring , and have fitted heated seats £40 when I get the bench seat cover. the switch just fits in the tank change over switch location (tank switch not in use) has 5 heat settings.  I made some door panel bottoms, same as new headliner material. I stitched the chevy emblem and the c10 logo on it first.
« Last Edit: November 12, 2017, 09:06:22 am by impco lpg »
Offline roundhouse
Re: rebuild
« Reply #17 on: November 13, 2017, 08:35:06 am »
Nice
Probably turns a lot of heads over there
I've seen a couple that were RHD
Offline impco lpg
Re: rebuild
« Reply #18 on: November 13, 2017, 12:14:22 pm »
there are a lot of c10 straight bodies over her but not this gen of stepside. and like you say a few RHD. I'm the only one in York with one  :). be glade when I get it back on the road been a long time, and a lot of man hours. got my K&N filter today £68 and some new silicone red radiator hoses £74 in meter lengths only. (yet to fit)
« Last Edit: November 13, 2017, 12:17:20 pm by impco lpg »
Offline impco lpg
Re: rebuild
« Reply #19 on: November 15, 2017, 12:13:47 pm »
there was no air con when I got the truck, some parts had been removed. (compressor/pipe work) so I have totally deleted the air con,(not needed over here) and this is the last bracket that needs to go. as its in the way. so I made my own bracket support so it still supports  the power steering pump. and cut the rest off. looks a lot better. also made bulkhead box so I still have heat and fan/blower still works.
« Last Edit: November 15, 2017, 12:29:04 pm by impco lpg »
Offline impco lpg
Re: rebuild
« Reply #20 on: December 16, 2017, 07:42:23 am »
still no carpet  >:(  so finished the red silicone radiator hoses, had to leave the bottom hose as original due to the shape  (is new anyway) gives it a new fresh look.
« Last Edit: December 16, 2017, 07:58:10 am by impco lpg »
Offline ChevTru
Re: rebuild
« Reply #21 on: January 02, 2018, 10:32:05 pm »
Looking great. Nice progress. Keep up the good work
Offline impco lpg
Re: rebuild
« Reply #22 on: January 06, 2018, 01:50:57 pm »
thanks,
got some new front park lamps. had to cut off the top two fixing tabs to fit my grill.
dismantled my bench seat, after removing the old cover and foam the some of the rear frame support bars have been cut out ?  so I have welded some more bars back in and painted the frame. I have 4 Brocken springs on the base frame, the foam also needs repairing on the drivers back and drivers seat.
« Last Edit: January 06, 2018, 02:22:02 pm by impco lpg »
Offline impco lpg
Re: rebuild
« Reply #23 on: January 06, 2018, 02:07:22 pm »
foam back repair first pic shows its already been repaired. so I have cut out the old and fitted some new high density foam. and then shaped it to the seat. and then covered it with polyester wadding on the frame. the base foam needs to be done the same
Offline impco lpg
Re: rebuild
« Reply #24 on: January 27, 2018, 07:44:42 am »
finally got the carpet in black, fits perfect with minimal  trimming to rear of cab.
fitted new hei 65,000 volt coil/distributor cap/rotor and control module. street thunder ignition leads. (as others were shot) I've always wanted to lift the truck suspension rather than body lift, but limited to height with it only been  2wd. it will have 2 inch rear blocks steel not cast as I have had in the past cast blocks crack. the front with 1 inch thick coil spring spacer, should lift it 2-1/2 to 3 inch.
made rear behind seat  trim panel needs another coat of paint, and will put chevy emblem on it.
Offline impco lpg
Re: rebuild
« Reply #25 on: January 28, 2018, 01:51:23 pm »
finished behind seat trim panel
Offline impco lpg
Re: rebuild
« Reply #26 on: February 07, 2018, 01:55:08 pm »
got carpet in, and behind seat panel fitted. new seat belts all round, just making some rear corner speaker pods 6x9 to match panel.
Offline impco lpg
Re: rebuild
« Reply #27 on: March 28, 2018, 02:44:57 pm »
seat cover turned up today, looks good quality comes with hog rings and pliers.
base of seat foam repaired then covered in wadding. new end springs fitted, heated seat elements in place cover next .
Offline impco lpg
Re: rebuild
« Reply #28 on: March 28, 2018, 02:56:43 pm »
seat cover base fitted, hog rings needed only on the ends of cover. front and rear has plastic fixings, makes fitting easier.
back of seat heated elements fitted, then cover fitted hog rings along bottom. turned out better than I expected. base mounts to fit then can go in truck.
« Last Edit: March 28, 2018, 03:01:09 pm by impco lpg »
Offline impco lpg
Re: rebuild
« Reply #29 on: April 05, 2018, 09:56:01 am »
rear corner speakers 6x9 came today, fitted to the pods. and bench seat in, a lot comfier than before. just needs insurance then M.O.T.
then back on the road.
« Last Edit: April 05, 2018, 10:10:19 am by impco lpg »
