Author Topic: side lights flash with indicators ( LED)  (Read 25458 times)
Offline impco lpg
Re: side lights flash with indicators ( LED)
« Reply #30 on: November 01, 2017, 06:43:28 am »
left bulkhead connector wires are;
blue = left indicator blue front loom wire
dark blue = right indicator blue front loom wire
dark brown = front park lamps black front loom wires (dark brown is park/running lamp feed)
brown = low beam brown front loom wire
green = high beam green front loom into relay
right bulkhead connector wires are;
dark brown = park lamps blue rear loom wire (dark brown is park/running lamp feed)
yellow = left indicator red rear loom wire
dark green = right indicator black rear loom wire
green = reverse/backup yellow and green rear loom wire
NO rear lamps tie-in to the brown wire
ONLY the white ground/earths tie-in to front and rear loom
I have not isolated the brown wire at this point !!
« Last Edit: November 01, 2017, 06:56:35 am by impco lpg »
1983 cucv m1009  blazer 6.2 4x4
1991 1500 suburban 5.7 4x4 lpg
2003 dodge ram 5.7 4x4 lpg
1985 chevy c10 stepside  2wd 5.7ltr 350 lpg
« Reply #31 on: November 01, 2017, 09:40:00 am »
Is the wire circled in yellow the dark brown wire coming from the "left bulkhead" connector?  If "Yes," place the diode here with the band orientated toward the forward lamps.
Offline impco lpg
« Reply #32 on: November 02, 2017, 07:14:33 am »
yes that is the left bulkhead connector in, and I have installed the diode toward the front lamps.
and everything is working FINE  :) NO RED FLASHING
I would just like to thank you BD for all your time and expertise  with this install I would not have done it with out you.
many thanks regards neil
« Last Edit: November 02, 2017, 07:37:20 am by impco lpg »
« Reply #33 on: November 02, 2017, 08:29:13 am »
You are quite welcome, Neil.  I'm happy to help.
