Author Topic: project onion rings  (Read 299931 times)
Offline chevn-up
Re: project onion rings
« Reply #30 on: June 26, 2019, 07:17:28 pm »
flexplate cover installed.
Offline chevn-up
« Reply #31 on: June 26, 2019, 07:18:08 pm »
yep.
Offline chevn-up
« Reply #32 on: July 01, 2019, 08:02:03 pm »
get'n there
Offline RossVE
« Reply #33 on: July 03, 2019, 08:49:20 am »
Very nice, I appreciate the attention to detail!
Sent from my ONEPLUS A6003 using Tapatalk
Offline chevn-up
« Reply #34 on: August 17, 2019, 09:21:29 am »
Finished with the heater blower install. This blower box is made of fiberglass. I knew that simply attaching the motor with screws would lead to breakage, as the holes are close to the edge.
Offline chevn-up
« Reply #35 on: August 17, 2019, 09:27:40 am »
I used 18ga. metal to fab a couple rings to reinforce the mounting location. Then I used silicone rtv on each side to "sandwich" the rings onto the box. It kinda glued it all together, super strong now.
Offline chevn-up
« Reply #36 on: August 17, 2019, 09:28:34 am »
again
Offline chevn-up
« Reply #37 on: August 17, 2019, 09:29:23 am »
Works like a champ.
Offline JohnnyPopper
  • Old Goof
« Reply #38 on: August 20, 2019, 04:45:28 pm »
Nice work man, looks like you cleaned up the firewall as well! Can't believe how bad they came from the factory- dented, smacked around, gross spot welding surfaces!
Why did you remove the air conditioning?
1980 C-10 under construction
Offline chevn-up
« Reply #39 on: August 28, 2019, 04:33:57 pm »
Bent-up the fuel line today. Replicated the original best I could.
Offline chevn-up
« Reply #40 on: August 28, 2019, 04:36:55 pm »
3/8" aluminum from Speedway Motors.
Offline chevn-up
« Reply #41 on: August 28, 2019, 04:38:26 pm »
A little Turtle wax and it polished-up nice.
Offline chevn-up
« Reply #42 on: August 28, 2019, 05:28:58 pm »
Almost forgot to mention, added this fuel filter.
Offline chevn-up
« Reply #43 on: September 22, 2019, 11:07:35 am »
Connecting to the Rochester is a bit of a challenge. Many of you might recognize this throttle cable bracket.
Offline chevn-up
« Reply #44 on: September 22, 2019, 11:09:06 am »
I didn't like it, so I made my own.
