Author Topic: 73-87 vent window ID  (Read 12365 times)
Offline MY1978
  • Just a girl and her truck since 1978
Re: 73-87 vent window ID
« Reply #15 on: June 27, 2021, 02:18:21 pm »
Hi,
I‘m sorry that i ask… I need the Vent Window Frame für my 1978 C10.
As I understand it here, I can also use newer Window frames, but looking at the part sellers , they all only offer the frames for 81-newer Chevy trucks.
http://store.73-87chevytrucks.com/merchant2/merchant.mvc?Screen=PROD&Store_Code=7&Product_Code=0850-257-258&Category_Code=7T
If I use a newer frame, do i also need another sealing and glas? In your link above (thanks for that!) they look a bit different.
It‘s also possible, that i missunderstood your replies. Reading in english for me is 60% understanding 40%guessing ….
Regards
Chris
Oh trust me, the 81 and newer will fit.  I pulled my vent windows from my '78 so that I could replace the seals.  Well........one frame was an 81-85 2-piece seal with the tabs and the other was an 85 -87 on piece with the hinge covered  WTH!!!!!!  How that happened I have NO idea.  I have only had a latch "fixed" at one time.  Not only did they install the wrong latch (one with a locking button), but they apparently switched out the whole frame.  How the other one got changed out, I have NO ideal.
Also, maybe this video will help.  https://www.youtube.com/watch?v=unq2ntN-14o
« Last Edit: June 27, 2021, 02:26:54 pm by MY1978 »
Offline ChrisD
« Reply #16 on: June 27, 2021, 02:32:18 pm »
Hi,
thank you for the video!
This will help me to disassemble the frame.
My problem is, the frame itself has lost some material because of rust.
Okay, i try to weld and grind it.
Regards
Chris
1978 Chevy C10 short bed with 250i6 and manual 3speed Saginaw
German us-car/truck newbie
Offline MY1978
« Reply #17 on: June 27, 2021, 06:11:49 pm »
Hi,
Regards
Chris
Glad the video was helpful.  Once you figure out your frame, they can be purchased from Summit, Classic Industries, maybe  , Ecklers maybe.  Depending on how much you want to spend, you can even purchase a complete vent setup.  Costly though.  $200+ dollars a window.  Other thought would be going to a salvage yard that has classics and strip one out of a junker.  Good luck.
Offline ChrisD
« Reply #18 on: July 21, 2021, 07:27:08 am »
Hi,
I‘ve found a store which sells the 73-80 vent window frame
https://www.prinstruckshop.nl/a-62063577/1973-86-serie-deuren/vent-window-frame-passenger-s-side-1973-80/#description
I just ordered one, if it‘s there, i‘ll report how it fits.
Regards
Chris
« Reply #19 on: August 15, 2021, 08:36:16 pm »
Since I posted this the vendor has almost everything for these vent windows available including the frame, glass, rivets and tool etc.  shoot me an email if you still need these.
