Author Topic: 350 tbi build recipe  (Read 16461 times)
Offline 90_suburban
« Reply #15 on: October 15, 2018, 02:46:41 pm »
You need to rationalize what you want to do within your end goals so I would agree, some overthinking. If this truck is going to be mostly street, drivability is a concern and the main reason you want to stay TBI is the convenience & you will be towing your trailer occasionally, then focus on that. The doubler the 12V, etc just adds more to the mix. You should devise a plan and build to suit.
So looks like the most rational would be a mildly built 350 I’d like close to 300hp at the flywheel would be enough I would think. Either the 4l80e or stick with the 700 with a np241 transfer case.
Off topic but will the dodge 241 passenger drop bolt to either the 700 or 4l80e. It has the 6 bolt round mounting.
« Last Edit: October 15, 2018, 02:51:45 pm by 90_suburban »
Re: 350 tbi build recipe
« Reply #16 on: October 15, 2018, 06:15:36 pm »
like vile said, think about where you want your power and go from there. towing and a DD low end is ideal to help you get up and going imo
Offline 90_suburban
« Reply #17 on: October 15, 2018, 06:37:20 pm »
I agree definitely want some low end grunt. And will definitely make sure I put a lot of thought into it before I pull the trigger on doing anything.
