Author Topic: Spark Plug Heat Range  (Read 8830 times)
Offline JohnnyPopper
  • Old Goof
Re: Spark Plug Heat Range
« Reply #15 on: March 12, 2020, 11:23:44 am »
It hasn't happened since I switched to IR plugs.
The standard plug fouled with carbon deposits, not oily at all.
I would just clean 6, then switch 6 and 8 every 3 months or so.
I would bet that pulling those plugs would still show a difference, just not as bad.
1980 C-10 under construction
« Reply #16 on: March 12, 2020, 10:22:52 pm »
Did #6 or #8 look like any of the following?
A -
B -
C -
D -
  • Old Goof
« Reply #17 on: March 13, 2020, 02:04:40 pm »
Something between A & B, though A is a little harsher.
« Reply #18 on: March 13, 2020, 02:38:05 pm »
So here's the skinny on the #6 spark plug fouling.  You are correct in that it does involve the EGR valve!  However, not in the way you suspected.  Because of the EGR valve's location near the right center edge of the intake manifold, exhaust heat is concentrated in that area of the intake manifold flange.  All that heat bakes the intake manifold gasket causing it to lose pliability and subsequently shrink ever-so-slightly.  At that point, oil vapor wafting in the valley pushes passed the gasket predominantly into the #6 and #8 intake runners.  The hot oil vapor partially burns in the combustion chambers, coating the spark plug insulators with hard ash deposits.  The effective repair solution is to replace the intake gaskets using Fel-Pro or similar aftermarket gaskets, sparingly smeared with some high-temperature Ultra Copper silicone sealer.  The precious metal spark plugs may work for a while but eventually, gasket replacement will become necessary.  So, now you have the rest of the story.
  • Old Goof
« Reply #19 on: March 15, 2020, 02:34:06 pm »
Queue Paul Harvey!
Thanks bd, you are the man!
