Author Topic: 1976 - Intermittent blower motor and turn signal(s)  (Read 12234 times)
Offline alfreema
Re: 1976 - Intermittent blower motor and turn signal(s)
« Reply #15 on: February 17, 2020, 02:37:24 pm »
Okay, good to know.   I think everything is working except possibly have corrosion in that one socket.   I will clean up all the sockets and verify everything is working.    Where do you guys purchase all the stuff needed for the conversion?
Offline 75gmck25
« Reply #16 on: February 18, 2020, 09:21:17 pm »
To remove an instrument panel bulb you just turn the black socket/cap behind it about 1/4 turn and the "socket" and bulb come out together.  If you have small hands. long arms, and a lot of patience, most of the bulb/socket assemblies can be removed by reaching up behind the panel while laying on the floor.
A little more explanation:
Each black socket has a metal strip around the inner edge that is flat up against the instrument panel circuit board, and there are also two bulb contacts inside the socket.
- When you insert a bulb into the socket it connects with the two metal clips/contacts inside.
- Those clips/contacts are connected to the metal strips on the edge of the socket.
- When you put the socket back into the cluster and turn it about 1/4 turn, the metal strips on the socket contact the circuit board and connect to power and ground.  The flat metal contacts can get tarnished or corroded and not make a good connection.
Bruce
Offline JohnnyPopper
  • Old Goof
« Reply #17 on: February 20, 2020, 07:54:17 pm »
   Ultimately, you will be very pleased with a good quality LED conversion.  They are far brighter than the OEM 194/168 bulbs.
Brings new meaning to 'dim bulb' ;D
I HATE how dim my dash is at night...
1980 C-10 under construction
