Author Topic: 85 K10 rebuild (aka CreamPuff)  (Read 31146 times)
Offline Mike81K10
Re: 85 K10 rebuild (aka CreamPuff)
« Reply #30 on: April 27, 2020, 07:20:24 pm »
Just for information! My Hobart 140 and the Lincoln 144 (?) has the ability to use Flux or MIG. I can only weld up to 1/4" steel. However, they work off of 120V. Your doing good and look forward to seeing the progress on your truck.
« Last Edit: April 27, 2020, 07:25:00 pm by Mike81K10 »
Offline melloyello
« Reply #31 on: April 27, 2020, 09:25:52 pm »
Had time to tackle the passenger side of the bed today. This section had 7 holes drilled in it and 6 spot welds holding it to the bottom skin. Judging by the bolt patterns, I would say there may have been 3 toolboxes used on this truck at different times. I don't ever want to see a drill bit near this bed again.
Patch panel in progress. It ain't fancy but it got the job done.
Panel fitted. Need to drill holes for spot welds. FYI: If you spot weld the top, it will draw your panel down when it cools and you will have to tap it back out.
And finished minus a little filler.
There were also 8 holes on this side from previously mounted bed rails
Couldn't get the whole side to show up but it's all filled in. Hopefully I'll have time to fill in the 7 bed rail holes on the other side tomorrow.
« Last Edit: April 27, 2020, 09:36:28 pm by melloyello »
Offline Mike81K10
« Reply #32 on: April 28, 2020, 09:13:46 pm »
You did really well, nice work.
Offline melloyello
« Reply #33 on: May 08, 2020, 11:58:01 pm »
Thank you. I'm working on a budget and part of this budget is "not spending all my money on body repairs by someone else". Plus, I get to learn as I go. I'm not a welder and definitely not a body guy. I can weld a little with a stick, mig or tig. But never have I attempted to weld such thin metal with an AC flux core welder.
Been spending some time on the bed sides the last couple of days.
Replaced a section in front of the drivers wheel opening
Someone's kid must have used this bed for target practice at some point.
Offline Mike81K10
« Reply #34 on: May 10, 2020, 08:31:54 pm »
Nice, clean, and straight. You are making good progress!
