Author Topic: 1980 C10 Restoration  (Read 62509 times)
Offline Mike81K10
Re: 1980 C10 Restoration
« Reply #15 on: June 09, 2020, 12:11:05 pm »
Believe that valve cover should be on the other side.
Offline JohnnyPopper
  • Old Goof
« Reply #16 on: June 09, 2020, 07:19:15 pm »
Or turned 180 degrees...  ::)
1980 C-10 under construction
Offline Ox350
« Reply #17 on: June 09, 2020, 09:56:15 pm »
Alright guys here it goes i got the valve covers on, new carb is next !!!!!!
Subscribe to my YouTube Channel to watch my Restoration on my 198O C10
Offline Mike81K10
« Reply #18 on: June 10, 2020, 11:02:33 am »
The valve cover on the right needs to be flipped around. The PCV Valve hole (driver Side) should be towards the front. The left (PS) one is OK.
« Last Edit: June 10, 2020, 04:15:22 pm by Mike81K10 »
  • Old Goof
« Reply #19 on: June 10, 2020, 11:14:34 am »
I guess the idea is to be able to read 'CHEVROLET' from each fender.
Offline Ox350
« Reply #20 on: June 10, 2020, 07:06:56 pm »
Mike I tried flipping it the way you said but for some reason it gets caught on the rocker arms  so I could only do it that way
Offline Geezer77GMC
« Reply #21 on: June 10, 2020, 09:34:13 pm »
GM spent good money designing oil seperators into the stock valve covers. The stock covers are not pretty, but quite functional. They also have a place to add oil into your engine, unlike those pretty covers, just saying. Also try a rag or blue painter's tape to keep anything from getting into those intake passages or manifold while the top end is apart.
Offline Mike81K10
« Reply #22 on: June 10, 2020, 11:30:45 pm »
Have you tried the swaping the two valve covers to the opposit sides? Look inside to see if there is an oil separator, they might be made for left and right side. The PCV valve should be at the front on the drivers side (not the back side of engine) and it appears swapping them to the other side might work.
Offline Ox350
« Reply #23 on: June 11, 2020, 09:26:27 pm »
Mike I’m going to get new bolts for the valve covers so I’m going to flip them one more time and see if it works.For the next few days I’m going to be taking the front end off of the truck I’m 95% sure I’m going to pull the engine Im thinking of going all the way with this restoration
Offline Ox350
« Reply #24 on: June 15, 2020, 11:34:29 pm »
Alright so this how it happened, i was like ok i will just remove the the clutch fan and radiator and just take off everything on the front of the engine tomorrow.
photo upload link
Then i was like man that really went too smooth what else can we get done lets just take all the pulleys of tonight
photo upload link
Ok the water pump was easy, so im like ok, all thats left is the 6 bell housing bolts, 3 torque converter bolts, and two engine mount bolts i mean what could go wrong right
Lets just get it out!!!!!!!!!!!
photo upload link
Then there it is, quick tips guys, dont forget to unbolt the trans dipstick it will leave a mess.....dont ask how i know also dont be lazy like me unbolt the starter
photo upload link
Finally the end result of a one man job!!!!!!!!!
photo upload link
« Last Edit: June 15, 2020, 11:45:03 pm by Ox350 »
Offline Ox350
« Reply #25 on: December 19, 2020, 11:11:47 pm »
Guys I’m back!!!!!!!! So like I said my plan is to give  this truck some life the engine bay and engine it self are so dirty. I’ve been working on the truck just haven’t had time to post.I’m doing a top end rebuild somewhat. I’m going to replace the lifters and install a mild camshaft, and install a new timing chain while I’m there.
Offline frotosride
    • WFO CONCEPTS
« Reply #26 on: December 19, 2020, 11:23:17 pm »
Looking good, so much easier to clean and upgrade out of the engine bay.
Quick tip, when you hoist that thing up again, put the largest washers you have at the end of the bolts in the heads, put some strain on it (don't lift it off the ground) then tighten the lifting bolts. It will be a rough day if that hook slips off the head of that tiny bolt. Keep up the good work.
Offline Ox350
« Reply #27 on: December 20, 2020, 01:46:01 pm »
Lol yeah I didn’t realize how shaky my setup was until someone else saw it and said I was very lucky nothing horrible happened
Offline Ox350
« Reply #28 on: December 20, 2020, 01:49:57 pm »
Now that I have it out and on a stand I’m going to clean it to get it ready so I can eventually paint it. I’ve done some reading online about using stove top cleaner for getting the funk off of these old engines. It’s working pretty good I’m just going to let it soak and then clean it off and see what we got let’s to wire brush off.
« Last Edit: December 20, 2020, 02:08:01 pm by Ox350 »
Offline Ox350
« Reply #29 on: December 22, 2020, 05:36:55 pm »
After removing the stove top cleaner from the engine it got most of the dirt and grime off the engine. I then proceeded to attack whatever was left with a gang of wire brushes and wire wheel attachments . Denatured Alcohol and wire brushes really got the engine pretty clean after a couple hours. Compared to the previous post I believe we’re headed in the right direction
