Author Topic: Change out Torque Converter while she's apart?  (Read 15063 times)
Offline Stewart G Griffin
Re: Change out Torque Converter while she's apart?
« Reply #15 on: July 13, 2020, 10:44:44 am »
Bizarre how ATI would recommend that converter.   You did give them the engine and cams specs?   The cam is very tame for a 383.  (nothing wrong with that as this is the beauty of cubes---you get good torque AND good top end without needing a wild cam.)
Let me pm you when i get a chance(i know a few guys there).
Also, as discussed above, let's make sure this is a "regular" TH-350 vs. a lockup   TH-350C
« Last Edit: July 13, 2020, 10:47:55 am by Stewart G Griffin »
Offline JohnnyPopper
  • Old Goof
« Reply #16 on: July 13, 2020, 01:43:19 pm »
Can say Stewart, perhaps VZ nailed it, calling him a box mover.
Although, he did ask me for all the specs that are listed on the data sheet, sounded like he was using a calculator, and then made that recommendation.
I can usually sniff out a poser, but he acted like he knew his stuff.
1980 C-10 under construction
Offline Curt80
« Reply #17 on: July 26, 2020, 12:58:14 pm »
Take the advice on here, 1800-2200 stall max.  I made the mistake years ago running a 3000 Hughes on a mild 350 w/ a Crane 272 cam similar to yours.  Ran hot, inefficient and not very derivable.   Wasn't even decent on the track.
