Author Topic: New Member with '75 Camper Special  (Read 1294 times)
Offline Powerhouse
« on: January 13, 2021, 10:14:00 PM »
Hello,
I am enjoying my recently acquired '75 Camper Special.  I am trying to learn more about my truck, and unfortunately the glove box door has been replaced and the original equipment list sticker is missing.  My particular set up has the 454 eng. TH400, and 4.10 gears in a 14 bolt rear end. It is my understanding that some of these camper specials came from the factory with a Detroit Locker, or a "No-slip" as it was once called.  I am trying to determine if that is accurate, and if I might have that or Poisi-traction in the rear.   Thank You!
Offline Mike81K10
Re: New Member with '75 Camper Special
« Reply #1 on: January 13, 2021, 11:41:35 PM »
Welcome from AL. Post some pics of your truck. Use JPEG format and adjust the pics to 500kb or less and attach them using the Attachments and other options below the text block.
« Reply #2 on: January 14, 2021, 07:51:42 AM »
Welcome from the St. Louis, MO area
1985 C30 Custom Deluxe Ext. cab 5.7L TH400 3.21
Offline Shifty
  • I bleed Bowtie red...
« Reply #3 on: January 14, 2021, 08:41:27 AM »
Welcome from Tucson, AZ!
Offline Powerhouse
« Reply #4 on: January 14, 2021, 04:07:44 PM »
Thank You,
I forgot to mention, CA truck. The smog exempt is nice. I will try to upload a pic. Trying to figure out how to ratchet down the file size of the pic so it can post.
I have a question: I am new to classic Chevy Trucks, and one reason (in addition to the good looks) that I went with the Square Body as opposed to 67-72, is because of the slightly larger cab.  I am 6' 5" and the extra room in the cab is well appreciated.  That being said, I find the steering wheel too close to my body and and the wheel being an extremely thin feel in the hands.  I feel like an ape scratching his chest when I am driving, so I am contemplating going with a shorter steering column, and thicker steering wheel.  Specifically a 30" column and a 14" wheel.
How long with this swap-out take, approximately? I will retain the automatic shift on the tree and the tilt function. Anything to be aware of that is unique to this job?
I am already converting to lower profile bucket seats which will help a little bit in the leg room area, and I am custom making some brackets that will mount the seat in the optimal position for me.
Thank You for any helpful info!
Offline frotosride
    • WFO CONCEPTS
« Reply #5 on: January 14, 2021, 04:48:29 PM »
Welcome to the forum and the Squares.
Well your choices are endless for columns. Pick chrome, or black, tilt or fixed, and then $$ or $$$.  One thing to remember to disconnect (if it still functions and hasn't been broke) is the cable for the gear shift indicator. It's just a small clip but when it gets hung, snaps off and flies away, You are reminded that it's there, was there.
1987 v10 Silverado, 87 R10,83 K20, 83 cucv 6.2 Detroit
Offline Powerhouse
« Reply #6 on: January 14, 2021, 11:48:05 PM »
here is a pic of the truck
Offline Shifty
« Reply #7 on: January 15, 2021, 08:30:49 AM »
Nice machine!
Offline carmen77
« Reply #8 on: January 15, 2021, 01:48:27 PM »
Nice truck!
Where in California are you?
Offline Powerhouse
« Reply #9 on: January 15, 2021, 08:39:33 PM »
Hello,
I am in the Bear Valley Springs Area near Tehachapi.  I am stoked today because I just received the bucket seats, and I fabricated some custom brackets to place them just right for me. Already a significant amount of interior room freed up from removal of the bench seat, and I have plenty of room for a custom center console that I am planning on building.
I may not nee to swap out the steering column after all.
Offline carmen77
« Reply #10 on: January 15, 2021, 08:46:54 PM »
Very cool.
Beautiful Seats!
Offline Powerhouse
« Reply #11 on: January 15, 2021, 08:52:11 PM »
Thank You!
Offline Powerhouse
« Reply #12 on: January 16, 2021, 11:58:37 AM »
Looking for some design ideas for the door panels to go with the bucket seats I just installed!
Thanks!
Offline JohnnyPopper
  • Old Goof
« Reply #13 on: January 19, 2021, 08:26:18 PM »
Welcome from SoCal!
Looks great! Where did you source the seats? (don't look Carmen ;D)
1980 C-10 under construction
Offline carmen77
« Reply #14 on: January 19, 2021, 08:30:37 PM »
Johnny,
It doesn’t matter where the seats came from because you aren’t in the market for bucket seats. You have a perfectly beautiful bench seat. Just saying....
