Author Topic: How to replace ignition switch?  (Read 38125 times)
Re: How to replace ignition switch?
« Reply #30 on: March 25, 2021, 10:43:10 pm »
The problem with interrupting the solenoid signal is that it can be bypassed easily and the engine cranked using a screwdriver.  Does your truck have conventional points ignition or has it been upgraded with HEI?
Offline Spool
« Reply #31 on: March 25, 2021, 10:53:34 pm »
HEI- you personally went above and beyond to help me with the job of replacing my distributor back in Feb of 2018.
« Reply #32 on: March 26, 2021, 12:55:03 am »
Use a cleverly hidden but accessible to you DPST mini toggle switch.  Connect two terminals from one side of the switch across the pickup coil wires.  Connect the two terminals from the opposite side of the switch between a good ground and the fuel level sender signal wire.  When the switch is activated, the ignition won't fire because the pickup coil signal to the ignition module is shunted and null.  At the same time, the fuel gauge will indicate Empty.  When the switch is deactivated, everything will function normally.  The idea is to spoof a would-be thief sufficiently that the normal tricks used to hot-wire wouldn't work such that (s)he would give up on it and look for a different target.  Of course, if you want to compound a thief's frustration, you could couple this approach with the 'defeat relay and magnetic switch' earlier suggested.
Offline Spool
« Reply #33 on: March 26, 2021, 03:18:51 pm »
Boy, am I glad I know you guys.
Both of these ideas sound awesome!
Let me locate my pickup coil and wrap my head around some of this before I properly respond.
