Author Topic: Mystery Wire  (Read 12219 times)
Offline MY1978
  • Just a girl and her truck since 1978
Re: Mystery Wire
« Reply #15 on: May 03, 2021, 07:34:16 am »
I found this wiring diagram (WHERE do I find one for my very own???) that shows the cruise control (which I have) has a double pink wire connection that plugs into the fuse block as a fused ignition.  Since I have not been able to drive the truck due to cab restoration, I have not been able to test this.  So, until I do, I think I will leave it alone for now and actually fix the exposed wires issue.  Stay tuned, this story isn't over yet!   :)
Offline Mike81K10
Re: Mystery Wire
« Reply #16 on: May 03, 2021, 02:53:44 pm »
That is the same as the wiring diagram I gave you a reference to on the forum. It is more of a compact version without the other wiring.
« Last Edit: May 03, 2021, 02:56:19 pm by Mike81K10 »
Offline MY1978
Re: Mystery Wire
« Reply #17 on: May 04, 2021, 05:58:40 am »
Yep Mike and thanks for sending that.  I am far from being a wire guru, learning as I go which I why I have posted stuff along the journey of the restoration.  This one was easier to understand and also shows the double pink fused connection at the fuse block.
But again, thanks for sending.   :)
Offline MY1978
Re: Mystery Wire
« Reply #18 on: May 05, 2021, 07:48:11 pm »
Don't like the way that bare wire looks coming out the connector. I would put a new terminal on it or at a minimum some heat shrink. Need to cover it.
Hey Mike, you will be happy to know that I took care of the bare wire situation.    ;)
