Author Topic: 305 Not Running Correctly. Unable to find problem.  (Read 8894 times)
Offline Shifty
  • I bleed Bowtie red...
Re: 305 Not Running Correctly. Unable to find problem.
« Reply #15 on: September 23, 2021, 09:35:30 am »
Great to hear that it's good again!
98 C2500 ext cab longbed
Offline JohnnyPopper
  • Old Goof
« Reply #16 on: September 23, 2021, 01:04:16 pm »
Well the upside is you have a lot of new parts on your truck! Although VZ's term "parts canon" begs to weigh in... ::)
I had a '66 Olds Toronado that had me floored as to why I had to completely advance the timing to get it to start.
Changed out the starter with a stronger one from a Eldorado, timing chain, ignition components, only to find that the coil had melted due to incorrect wiring.  >:(
Glad this ended well.
1980 C-10 under construction
