All Classified forums require a Site Supporter subscription. It is only $25 per year and you can buy and sell whatever you like on the forum. To become a Site Supporter, go to Your Profile and select "Paid Subscriptions."
I was fishing some new wire through the firewall in my '87 Suburban V20 recently and I noticed it no longer triggers the chiming sound when the key is turned to the "ON" position.
Quote from: Jon87V20 on April 24, 2022, 06:56:50 pmI was fishing some new wire through the firewall in my '87 Suburban V20 recently and I noticed it no longer triggers the chiming sound when the key is turned to the "ON" position.It's not supposed to chime in the key ON position. Reiterating, the chime should sound: (1) with the key in the ignition, ignition OFF, door open, (2) key in or out, ignition OFF, running lights ON, and (3) for 3-5 seconds when the ignition is initially switched ON with the driver seat belt unclipped. The wires dislodged from the door switch are likely the cause.
bd, I guess what I've been hearing is the seatbelt chime this whole time and thought it was normal. This actually makes perfect sense because I replaced the seatbelts completely that same day as well. Cased closed! Thanks.
Quote from: Jon87V20 on April 25, 2022, 01:19:55 pmbd, I guess what I've been hearing is the seatbelt chime this whole time and thought it was normal. This actually makes perfect sense because I replaced the seatbelts completely that same day as well. Cased closed! Thanks.Where did you order your seatbelts from? Are you happy with the quality? Thanks for your time responding.
