Best Protective Coating for frames and under body?
Topic: Best Protective Coating for frames and under body? (Read 3548 times)
Chevynut73
March 31, 2023, 04:52:43 pm »
Would like to clean and coat the surface rust from under the C10.
What have y'all used and liked?
Thanks
'73 Chevy C10, 350, TH350, was a long Fleetside, now she's a short Stepper that's under construction (been in the Family since 1972).
Would rather push a CHEVY than drive a Furd
Swampyankee74
Keep em alive
Re: Best Protective Coating for frames and under body?
March 31, 2023, 05:48:20 pm »
I used chasis saver on a blasted frame. Truck hasn't been on the road since, but it's on there like a rock, smash it with a hammer, dig into with a wrench, it doesn't come off. Think I still have some on my skin from 3 months ago. So far very happy-just my uninformed opinion...
Sent from my SM-S515DL using Tapatalk
JohnnyPopper
Old Goof
March 31, 2023, 10:07:09 pm »
I used this stuff.
Sprays on nice and uniform, rubberized too.
1973 C-20, 3+3 454 4BBL TH400 Water Injection
1980 C-10 under construction
zieg85
April 01, 2023, 02:13:44 pm »
It all depends on your surface prep. Good paint over so-so prep is worse than bare. The coating locks tightly together and moisture gets underneath and rust forms. My $.02
JohnnyPopper
Old Goof
April 01, 2023, 07:47:48 pm »
I soaked all the front end components in a molasses water 1:9 mixture in a 44 gallon trash can.
They came out as bare metal. Rinsed off with water, let dry and sprayed them with a couple of coats.
Some parts that were really coated with gunk took longer than others.
Swampyankee74
Keep em alive
April 01, 2023, 08:32:50 pm »
I got to try this molasses trick. Can you keep the mixture around for a while or does it go moldy?
JohnnyPopper
Old Goof
April 02, 2023, 06:35:53 pm »
You can keep it, it doesn't lose it strength.
Keep it covered though with the trash can lid.
B/C after you use for a while it smells like dirty gym socks.
Oh, and don't leave any parts longer than needed to clean them, B/C it will continue to eat the softer elements of ferrous metal, and softer things like sheet metal. Ask me how I know...
Swampyankee74
Keep em alive
April 02, 2023, 06:48:12 pm »
I like what I hear! In gonna set up what I call a brew pot and try it out. Gonna try it with parts I don't need. But looking at your pics it works wonders.
April 05, 2023, 10:14:15 am »
I have used POR15 and Chassis Saver with good results for frames.
When it comes to underbody, on the outside I have primer sealed them and used rubber coating or raptor liner type spray on material.
Chevynut73
April 07, 2023, 12:01:10 pm »
Great information - thank y'all
