Author Topic: 3 wire to 1 wire alternator  (Read 28888 times)
Offline Swampyankee74
  • Keep em alive
Re: 3 wire to 1 wire alternator
« Reply #30 on: July 11, 2023, 11:21:52 am »
Sounds good, it's going to be a  little bit. Nose is still off the truck, painting core support inner fenders and such. Then to put the nose together. I'm leaving tomorrow thru the weekend for Ohio for Eldora kings royal race. But I will post when I get it up and working.  I think you nailed it tho!
  • Keep em alive
« Reply #31 on: July 17, 2023, 08:47:07 pm »
I ordered 1 foot of 10 guage fusible link wire for between the junction block and the starter. Just to verify, even though this is a foot long I still need to cut it down to 6" for it to function properly?
Sent from my SM-S236DL using Tapatalk
« Reply #32 on: July 17, 2023, 11:34:33 pm »
All fusible links are 6" long.  Also, the length of the 6-gauge cable connecting the starter solenoid B+ stud to the firewall junction block should match as close as possible the length of the 10-gauge cable it replaces.
  • Keep em alive
« Reply #33 on: July 18, 2023, 03:09:06 am »
Sounds good BD, thank you!
  • Keep em alive
« Reply #34 on: July 18, 2023, 08:15:12 am »
Can I solder the 10 guage fusible link to the 6 guage wire or will that destroy the fusible link?
« Reply #35 on: July 18, 2023, 09:36:01 am »
First, firmly crimp the wires using an uninsulated, brazed barrel butt splice or parallel splice for a solid mechanical connection.  Second, solder the splice using 60/40 rosin core solder.  Third, seal the splice using marine grade dual wall, adhesive lined polyolefin heat shrink.  Follow similar procedures for the 3/8" and #10 eye terminal ends.
  • Keep em alive
« Reply #36 on: July 18, 2023, 11:07:17 am »
Thank you bd. Wasn't sure if the heat would ruin it
« Reply #37 on: July 18, 2023, 12:38:58 pm »
A fusible link is just an annealed and tinned, high strand count copper wire jacketed in Hypalon insulation.  The insulation provides a temperature tolerance of >300° F.  Unless you use an open flame, the insulation will not be damaged by soldering.
  • Keep em alive
« Reply #38 on: July 18, 2023, 01:21:17 pm »
Gotcha, thanks again
