Author Topic: Found a Quadrajet  (Read 42398 times)
Offline Mr. Machanic
Re: Found a Quadrajet
« Reply #15 on: December 25, 2023, 08:56:55 pm »
I agree. This carb is a hot mess.
But, it is doing exactly as intended and that is to serve as a teaching tool.
I did not want to tear into mine, having never tore into one.
The goal is to make a reasonable effort and possibly have a usable carb.
I have done quite a few motorcycle carbs from early 70's big bikes and there has been plenty of times when one turns hopeless. It took a only a couple of carbs to learn when it's junk.
I even made jets for one of my bikes.
I really enjoyed that learning process.
A few have said, just throw a holley on it, but where's the fun in that?..lol
1978 Big 10 "Bigg'in"
350/350 auto.
Cordova Brown Scottsdale
Zero pollution krap.
Suck, Squeeze, Bang, Blow
« Reply #16 on: December 27, 2023, 01:54:21 pm »
Hot Digitty X2.
I love craigslist.
I found 2 more QJ's for $20 each.
One has numbers the other looks identical but lacks numbers.
Again, these are just "teaching tools".
I have no desire to rebuild either of these, just learn from them.
When I played with bikes, there was a bike salvage yard about 10 miles from me.
They would let me rummage thru the rows and rows of bikes and unbolt whatever I wanted, as long as I didn't make a mess. Great times for sure.
350/350 auto.
« Reply #17 on: January 02, 2024, 03:06:33 pm »
Finally, after the businesses opened back up, I went to my local bearing house and picked up some bronze cintered (a.k.a. Oilite) bushings for the primary shaft.
About an hour-ish later, the plate was done.
It went very well and was not at all difficult.
350/350 auto.
« Reply #18 on: January 02, 2024, 03:47:05 pm »
After a little clean up, the shaft was slid in to check fit and alignment.
Boy, did that make a huge difference.
I am super tickled with the results.
Now for a good careful cleaning and it will be ready to go back together.
BTW, of the professional carb rebuild guys I spoke with, the one mentioned they don't resleeve the secondary shaft at all. Apparently, there has been binding issues with the shaft after a few months on the road.
So this one won't get the secondary shaft resleeved.
We'll see how that goes.
350/350 auto.
Offline JohnnyPopper
  • Old Goof
« Reply #19 on: January 02, 2024, 08:56:43 pm »
That's a lot of heavy lifting Mr. M! Understandable on secondary  bushings, not used very much relative to primaries.
1980 C-10 under construction
« Reply #20 on: January 03, 2024, 12:52:24 pm »
JohnnyPopper,
I'm not familiar with the term "heavy lifting" but I'll assume it means "not easy work".
If so, I understand. But, to me it is not hard or difficult at all.
Honestly, If someone came to me and asked if I'd toss a couple bushings in that plate, sure, not a problem and $40 would make it worth my while, and I even have the bushing.
Having a hobby of small steam engines, installing bushings and bearings is pretty basic stuff.
350/350 auto.
  • Old Goof
« Reply #21 on: January 03, 2024, 07:47:22 pm »
I can see where your hobby skill set comes in handy. Good to know!
In '79 I came across a Fairbanks Morse Z gas engine, pre-spark plug, complete.
I restored it and got to run. My autoshop teacher called them 'johnny poppers'.
« Reply #22 on: January 03, 2024, 08:01:46 pm »
J.P.
Was that Fairbanks the one with firetube ignition?
A friend had a MayTag washer engine that had a firetube ignition.
You heated the tube with a torch until it glowed then it would act like a glow plug and run the engine.
Cute little engine.
350/350 auto.
  • Old Goof
« Reply #23 on: January 03, 2024, 10:48:36 pm »
Wow never heard of a firetube! Sounds ingenious.
No, this had a set of spring loaded contact points that were mechanically closed by a linkage arm from the gearing off the crank.
It had a centrifugal governor that would expand when the rpm was correct, cancelling the spark till it retracted, then the next POP.
The firing was intermittent, POP---PO PO POP-POP
I don't think this is the exact model but close.
  • Old Goof
« Reply #24 on: January 03, 2024, 10:51:19 pm »
The points were inside the combustion chamber.
« Reply #25 on: January 04, 2024, 12:16:44 am »
Oh...
A Hit-n-miss engine.
Them be kewl too.
350/350 auto.
« Reply #26 on: January 07, 2024, 04:20:17 pm »
Polishing the bores.
Not that I'm certain it makes much difference, but someday, somebody may look down this carb and recognize the fact that somebody spent some time on it and "loved" it...lol.
350/350 auto.
  • Old Goof
« Reply #27 on: January 07, 2024, 08:12:43 pm »
I don't know Mr. M...
May be the pics but it looks like what I commented earlier, 'found at the bottom of the pool' with all the surface pitting.
Are you going to use a bore hone to clean up the secondaries?
« Reply #28 on: January 07, 2024, 08:24:59 pm »
LOL...
Actually it's cleaning up very nicely.
Wait till I get the one on the truck off...it looks like a racoon took a pooh in it.
I'm using a flex shaft handpiece with 180g round wrap cartridges. My first career was as a Journeyman machinist/moldmaker, so blending uneven edges is no big deal.
The secondaries are very smoof and shiny.
I'll post pics tomorrow.
350/350 auto.
« Reply #29 on: January 07, 2024, 10:16:32 pm »
Before and after.
Took a bit over half hour.
350/350 auto.
