Author Topic: Pinion Angle Help  (Read 74999 times)
Offline JohnnyPopper
  • Old Goof
Re: Pinion Angle Help
« Reply #30 on: March 26, 2024, 09:18:13 pm »
Push up / Pull down slop is what mine had before I replaced it.
There should be no movement.
Vibration is now gone.
1980 C-10 under construction
Offline Backwoodsballer
« Reply #31 on: March 27, 2024, 07:06:57 am »
Awesome, thanks JohnnyPopper.  I think we are starting to narrow this down.
Ill call into to Tom Woods today and see if they think i should stick with the conventional shaft (OEM) with a single joint on either end or if i should just move up to a double cardon joint.
1978 K10 Cheyanne Long Bed
350 / TH350 / NP203 Part Time
Offline bo3mrr@aol.com
« Reply #32 on: March 29, 2024, 08:50:13 pm »
I would drop the transfer case first.  It will more than likely take care of it.
« Reply #33 on: April 08, 2024, 07:22:20 am »
Just wanted to post up my findings after installing the Tom Woods Double Cardan Shaft.  The vibrations are definitely less now with a proper shaft and proper angles for the double cardan.  The remaining vibration im having are likely related to the wheels i have so ill be taking them to be balanced soon.  I ran the truck up to 72mph yesterday, and the only vibration i felt was one that seemed to be tire related.
Thank you all for your help!!
  • Old Goof
« Reply #34 on: April 08, 2024, 03:27:11 pm »
Happy ending! Love it!
