Author Topic: Dualjet cruising lean hesitation  (Read 150865 times)
Offline Shifty
  • I bleed Bowtie red...
Re: Dualjet cruising lean hesitation
« Reply #15 on: July 08, 2024, 09:52:19 am »
Or the rubber at the tank end is split, and sucking air, or soft and sucking shut.  The amount of ethanol in todays gas is high, and not very rubber friendly.
I actually replaced all the hoses when I replaced the tank.
I used the stuff rated for alcohol
BUT I actually found a gas station here that sells ethanol free, so that's all the truck and my other old cars get
It's a dollar more per gallon but worth it not to be tearing into the carbs all the time
I'm jealous!  ;)
98 C2500 ext cab longbed
Offline Scaryfastatx
« Reply #16 on: July 14, 2024, 02:35:48 pm »
I was shocked to find it to be honest. But all the Quick Trip gas stations here have it now. So I get ethanol free for my truck and the lawn mower haha
I'm jealous!  ;)
« Reply #17 on: July 14, 2024, 04:52:44 pm »
So today worked on the truck more still haven't found the problem, getting really frustrated
I'm thinking maybe it's the vacuum lines
So I pulled everything and wanted to rerun them with new lines
My big question is, where does the vacuum advance hook up? The ports aren't labeled on my diagram
I had it originally hooked up to the port on the base plate, but read on another form for G vans where the guy had a dualjet and his distributor was connected to port B
Thanks
Offline JohnnyPopper
  • Old Goof
« Reply #18 on: July 14, 2024, 10:42:59 pm »
So obvious question: Is smog compliance still part of your truck's existence?
If yes, then keep digging.
If no, then apply direct manifold vacuum.
1980 C-10 under construction
« Reply #19 on: July 14, 2024, 11:08:22 pm »
It's not smog compliant, it's older than 25 years so they don't make us test them anymore for inspection
So is the port I need to connect to the lower passenger side one?
  • Old Goof
« Reply #20 on: July 15, 2024, 09:37:45 am »
My understanding is that all ports on a carb are metered except the EGR.
Direct manifold vacuum bypasses that.
Look for, or create a port that goes directly into the intake manifold.
If you have an automatic transmission that has a vacuum operated modulator, that would be a good source to tap into.
« Reply #21 on: July 15, 2024, 02:21:12 pm »
Well I got some time today, and put my vacuum gauge on the ports
Port B is full manifold vacuum and port on the bottom passenger side is ported
Fingers crossed that does the trick
« Reply #22 on: July 16, 2024, 08:35:03 pm »
Well, I don't know what else to check
On vacuum port B it felt a lot better with the full manifold vacuum
But got it out on a more open road that I could get some speed and it's still cutting out
Usually at higher speed
If I downshift and get to the rpm where it's stumbling it seems fine
Also if I go really light on the throttle up to speed sometimes it will go faster and maintain the speed
But it's intermittent and will also stumble sometimes
But if I go heavier on the acceleration it stumbles quicker
Other times it stumbles at really low speed
I'm really confused and frustrated
« Reply #23 on: July 16, 2024, 09:59:22 pm »
Have you inspected the spark plug electrodes and checked the ceramics for cracks or carbon tracks?  Check the spark plug wires for hard spots especially where they route near metal edges and the exhaust manifolds.  Use a bright flashlight to look up inside the spark plug boots and the distributor boots for black soot or green discoloration.  Inspect the cap & rotor for black carbon tracks and cracks.
« Reply #24 on: July 16, 2024, 10:10:58 pm »
I'll check it out
The plugs and wires are basically brand new
I thought for sure it was either fuel or timing but seems like those are fine
« Reply #25 on: July 28, 2024, 06:37:00 pm »
I think I may have cracked the case!
I was reading through the service manual about engine cut out at higher speed and it had a procedure to do pump down on the fuel lines to see if it is sucking air
So I have a fuel filter in line where the lines cross the bed and go onto the frame rail
I pulled it and did a pump down and it read ~14in Hg
I then was going to lower the tank to tie my vacuum gage in when I saw this (fairly new yikes)
Once I dropped the tank completely looks like there was some minor leakage on the fuel feed line, so definitely was sucking air
So I put my lines back on and pumped down and it's looking great
Think I may have cracked the case
« Last Edit: July 28, 2024, 06:41:40 pm by Scaryfastatx »
Offline Shifty
« Reply #26 on: July 29, 2024, 09:31:40 am »
Todays rubber is doo-doo.... :(
  • Old Goof
« Reply #27 on: July 29, 2024, 09:05:04 pm »
So when will we know Mr. Scary??? Great detective work BTW.  ;D
« Reply #28 on: August 03, 2024, 11:09:34 am »
WELP!
that was not the problem. I ordered some clear gas approved tygon tubing and a tee fitting, gonna check for bubbles, flow and pump down
Also thinking to swap to an old Edelbrock carb I have just to do a comparison and see if maybe something is wrong with the carb that the rebuild didn't fix (power valve?)
« Reply #29 on: August 11, 2024, 05:11:59 pm »
