Author Topic: 55 mph on highways ?  (Read 64884 times)
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
Re: 55 mph on highways ?
« Reply #15 on: July 26, 2024, 09:31:37 pm »
Wow Kenny, I'm glad that you're ok enough to post that!  Did the rager get charged?
It was several years ago.   I didn't even get a bump on myself...  old truck was heavy and I was holding the brakes as hard a i could.   he didn't move it much was why he left so much of his car behind.   Guy had no tag at all.  cops said likely a stolen car.   Rager got away.   I'm totally okay with that because it didn't step up to the next level.   any time things do step up to the next level I'm okay with it when only vehicles got damage.  I've wondered what happened tho to the other drivers that were involved in the pileup.  It was Sunday and there were several mini vans in there.   I hope they are OK.
Offline berserk
« Reply #16 on: April 08, 2025, 11:10:45 am »
Edit: post rambles on so I removed it.
« Last Edit: April 10, 2025, 05:03:48 am by berserk »
76 Chevy k10 350/th350/203 part time. Vortec head 350 Dana 60 w/Detroit, 14 bolt Tru Trac, 33" Micky T. Mudders.
« Reply #17 on: April 08, 2025, 12:27:15 pm »
I've run dozens of square bodies, & other trucks with everything from 235/85/16 to 35" rubber with 4.10 gears. 70/85 MPH no worries. You should figure out where the vibration is coming from though. If you're towing being a 1/2 ton you might want to keep it around 60, maybe 65 MPH though.
Are your tires E rated?
Offline berserk
« Reply #18 on: April 08, 2025, 12:47:37 pm »
Edit: Starting thread for the specific issue I am having with vibration which is separate from this threads topic.
I agree, look at the post just before yours where I'm asking advice. Yes I have Mickey Thompson 10 ply E rated.
« Last Edit: April 10, 2025, 05:03:11 am by berserk »
Offline AsolMarandy
« Reply #19 on: December 22, 2025, 08:46:11 am »
Many older trucks run like this on the highway. A TH350 with 4.10 gears and 33 tires will turn high rpm at speed. Running 55 is normal for that setup.
Staying in the right lane helps. Using hazard lights when traffic stacks up can help. Pulling over when there is space helps too.
Fixing the driveline vibration should be a priority. A vibration makes highway driving harder.
A gear change is an option later. A 3.73 or 3.55 gear will lower rpm. An overdrive swap like a 4L80E also helps, but it can wait.
Old trucks were not built for fast highway speeds. Watching the road ahead and letting others pass is the safest approach.
« Reply #20 on: December 22, 2025, 03:16:41 pm »
I ran the 70mph with the 4:10 and a th400.  RPM's were up for sure but other than that easy peasy... I did eventually gear mine to a 3.21 and loved it.
