Author Topic: TH350 Dead  (Read 76716 times)
Offline JohnnyPopper
  • Old Goof
Re: TH350 Dead
« Reply #15 on: August 09, 2025, 08:43:54 pm »
Wow Shifty- I should look for the DIY rebuild on YT!
If it's that ubiquitous there are probably many ways I can save $.
Granted, I have never ventured into automatic transmissions, but one can grow facing their fears.
Know a guy who kept worn clutch discs within a certain tolerance, to use them to recreate the standard stack of clutches called for.
His reason was that more clutch surface was better. Sounds reasonable... 8)
1980 C-10 under construction
Offline 1980K20
Re: TH350 Dead
« Reply #16 on: August 09, 2025, 09:33:38 pm »
Thanks all!  I put it back together, filled it up and drove around the block successfully.  Transmission guy suggested to drive it over on Sunday so there’s less time on the road and i have more time for tow truck just in case.  Good idea.
He’s confident in his ability to rebuild this, as you say very straightforward.  I asked about buying a tci or something.  I got an earful about cheap parts, sometimes good builder sometimes not.  So I’ll have this guy rebuild it.
I’ve got engine oil coming from the converter cover.  Rear seal?  Also some coolant, another surprise.  They’ll correct whatever else is wrong while it’s up.  Probably going to be a month or two.  They have two lifts for classics.  They’ll pull my tranny inbetween other classics.  So i have to wait for a lift to open after it’s rebuilt.
Bought some magnets but my pan is aluminum.  Surprised the drain plug did not have a magnet.  I stacked some magnets on the outside of the drain plug.  May not do much.
1952 International L112 - waiting for EV conversion
1967 Camaro - 250 six cyl, 200-4R
1980 K20 4x4 Fleetside - 350 SBC roller Cam, TH350
  • Old Goof
Re: TH350 Dead
« Reply #17 on: August 10, 2025, 12:57:20 pm »
It's amazing what good circulation does for both animate and inanimate subjects.
If you use the same pan, put one magnet inside the bottom of the pan and an opposing magnet underneath, or outside the pan.
You can clean them off during the next service/filter change.
Re: TH350 Dead
« Reply #18 on: August 13, 2025, 08:56:29 am »
You can epoxy a magnet in the pan if you want one in there.
Offline 1980K20
Re: TH350 Dead
« Reply #19 on: August 20, 2025, 12:22:27 am »
Transmission guy will do what needs to be done.  He says sometimes the torque converter fails, bearings then stuff starts grinding.  Then when the filter clogs the pressure drops and the clutches burn up.  Oh what fun.  If it was the TC, can’t blame the rebuilder on that.  Hope next one us quality.
Beyond the transmission rebuild and a new TC, he’ll run a hot fluid filter 30 minutes in each direction to thoroughly flush the coolers (i use both radiator internal and external cooler to ensure a level temperature).
My stack of three harbor freight magnets were still attached to the drain plug.  Thanks for the suggestions on magnets!  I’ll get something in place.
I expect this will take a while.  As I get info, will update to provide others benefit and amusement (better you than me category, eh?).
  • Old Goof
Re: TH350 Dead
« Reply #20 on: August 20, 2025, 05:59:30 pm »
Sounds like a quality shop, I like the flushing of cooling lines both ways.
Yes, the key to longevity is keeping them clean. Seems to be the most overlooked service item in history!
Offline 1980K20
Re: TH350 Dead
« Reply #21 on: September 03, 2025, 12:00:30 am »
The torque converter was blown.  The rear drum was worn, should have been replaced in the first build.  Seals in transfer case leaking.  Oil pan appears to be leaking. Will replace rear main seal on engine just in case.  There’s a coolant leak, likely from intake manifold (which i have to do myself).
They’re fixing everything except intake.  Cha-ching.  At least it will work.
Maybe get it home next week?  Then for the break in.
Offline Shifty
  • I bleed Bowtie red...
Re: TH350 Dead
« Reply #22 on: September 03, 2025, 11:34:23 am »
Sounds like you have a plan, keep us updated!
98 C2500 ext cab longbed
Offline 1980K20
Re: TH350 Dead
« Reply #23 on: September 06, 2025, 11:23:30 am »
Stopped by yesterday.  The bearing in the torque converter failed.  It was new, good reputable brand, same as what he’s replacing it with.  “Sometimes you just get unlucky” :-(
All the metal coming out was grinding down the forward shaft (i don’t know proper names).  But this shaft was loose, not pressed securely into the forward drum.  New drum and shaft of course. Clutches were not burned but he’s replacing them anyways so it’s known to him.
I get a three year warranty on the work.
Trying to fix the leaks.  The 4x4 switch leaks.  No replacement.  Can’t just put a bolt on it, requires detent with funky threads.  Will probably have to epoxy the heck out of it and cross fingers.  Suggestions anyone?
  • Old Goof
Re: TH350 Dead
« Reply #24 on: September 06, 2025, 11:37:50 pm »
"Too wonderful for me to understand"- King David of Israel...
Hope it works out for you bro.  8)
Offline 1980K20
Re: TH350 Dead
« Reply #25 on: September 12, 2025, 08:57:54 pm »
Truck is home!  Shifting is smoother than the last build.  Drive home, most oil leaks should be solved.  Replaced a sketchy freeze plug too.
Just looked for drips, looked like some engine oil drip but no transmission or transfer case oil yeah!
  • Old Goof
Re: TH350 Dead
« Reply #26 on: September 13, 2025, 12:42:58 am »
Congrats man!!
Happy for you... :)
Offline 1980K20
Re: TH350 Dead
« Reply #27 on: September 14, 2025, 10:28:08 pm »
Thanks all!  Took her for an outing yesterday, everything is in order.
On to bigger and better!
