Author Topic: A/C COMPRESSOR  (Read 22613 times)
Re: A/C COMPRESSOR
« Reply #15 on: September 19, 2007, 09:56:51 pm »
.....all for under 180.00 dollars..  <you can't beat this anywhere>
That is pretty cheap for a shop!
Offline 83HighSierra
Re: A/C COMPRESSOR
« Reply #16 on: September 19, 2007, 10:07:47 pm »
no i havent been any where around there.
So what about my compressor, it just clicks on and off or is that because there is no freon in it. by the way thank you guys for all the help
« Last Edit: September 19, 2007, 10:25:24 pm by 83HighSierra »
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: A/C COMPRESSOR
« Reply #17 on: September 20, 2007, 09:23:21 pm »
it clicks on and off because the pressure switch on the accumulator detects low pressure and kills the circuit for the compressor (green wire).  You can jump that switch for a minute or two (not long though, it is bad for the compressor in low pressure situations) and see if the compressor kicks on.   REmove the plug on the switch.  Look in the plug, you see two wire contacts. Take a wire and and connect the two wire contacts w/ a/c on and engine running.  Does compressor kick on?
Years ago, i had a bad pressure switch ($14.00).  I knew the pressure was high, but compressor wasn't working.  I unplugged the switch and jumped the two wires---compressor came on.
« Last Edit: September 20, 2007, 09:25:27 pm by SgtDel »
