Author Topic: Should I keep the q-jet??  (Read 12947 times)
Offline baddogg79
Re: Should I keep the q-jet??
« Reply #15 on: October 14, 2007, 07:59:03 pm »
Thats great! hopefully when I get one that happends to me 8) When I get the cash for an intake, ill get one to rebuild.
« Reply #16 on: October 14, 2007, 09:27:20 pm »
I had someone give me one off a 500 Caddy motor one time. That was the best running Q Jet I have ever had. I had it on a mild 350 RV cam street motor in a 3/4 ton truck. I was told by an old timer mechanic that the caddy Q Jets had bigger jets etc.?
Offline baddogg79
« Reply #17 on: October 14, 2007, 09:38:24 pm »
ill have to look into that, if it is true, I might look for one of those. I am planning on putting a nice cam and intake combo. The one day, some heads, might not do the vortec thing :-\
Offline 85MudMonster
« Reply #18 on: October 23, 2007, 06:08:09 pm »
I've dealt with a few olds q-jets (their the same thing) and they are a pain the the ass, but if you can tune them just perfectly it will be the best carb you'll ever own, but if you want easy tuning, get a holley. The Q-Jets usually, at least the ones I've worked on where all 750cfm from the factory, which means it'll outflow that little 600cfm edelbrock you replace it with. Just read up on them they can be tuned to do anything you want, make power, or fuel economy (usually how they where tuned from the factory), you just have to learn what it takes to make it just right.
Dan
85 Chevy K10 - 408 BBC from a 71 Chevelle SS, TH350, NP208, 33" Mastercraft Courser M/T
